07 Differential
I have a 2007 Silverado nbs and need some help. Now, i know GM's reputation on transmissions and differentials and think i might be adding my truck to the list soon. Whenever i lose traction in the rear-end for whatever reason, when the locker kicks in it hits rather hard and feels like it is going to grenade. :M16: Is this normal or did i get a bad rear-end? As for the tranny, I am in the process of finding some parts to rebuild and give it a little more strength. How does a performance rebuild kit and shift kit sound for the tranny? :fume:
My G80 will at times engage rather hard, and I don't abuse it. Is this "normal", I'm not sure. But, I don't care if I hear or feel my tranny shift or the differential engage, as long as it works well :fume: .
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
