Really Cold Starts
michaeljoeb
I have a 2001 3/4t Duramax that leaves traces of pink fluid (transmisson) on the snow whenever I start at -15C or below. Just a few drops but it still is a bother. My dealer says it's normal???
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,133 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
