What Is This Devise?
rjh1936
I have a 1990 G30=TBI van cut-away on my motorhome. I need to identify some items under the dash and need help. The item has 7 wires as follows. blue, purple/white, white, rede/white, black, and green on on plug. yellow on the other plug. I could not find wires matching this in Chiltons, the only manual I have. The item has PNZ and part *36PNZ R244402* on it's label Anybody know what this is? Thanks
I was hoping I read it wrong, that # does not shop up in GM system any more. So bear with me it will take a few to locate that wire harness. It also makes it hard that your van is a conversion van. It appears to be an add in the way it is mounted.
Does your van have daytime running lights?
What is your vans VIN # you can send it to me though personal email on this site if you would like.
With the VIN. Your vehiclwe is a Canada veh which back in 1990 it was required that all veh have daytime running lights. Looking at the wire colors in the pic they match the wire diagram for the daytime running lamp module.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,355 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
