Flowmaster 50 Series
s2per
REVISED PRICE--I was a little high......the price that is....
Single 2-1/2" inlet, (2) 2-1/4" outlets. Used in catback dual application on 2006 Sierra 1500 5.3 EC/SB.
Muffler is 17-1/2" long x 9-1/2" x 4-1/4" oval shaped. Stamped with 3406S 9425502 part number. Over $130 list price
I had this muffler on my truck for about 4 months, and it was just a little too loud for my middle-aged tastes. Still has 95% factory paint. $50 SHIPPED TO YOUR USA MAINLAND DOOR!! [email protected]
Still F/S?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
