Axxees Ipod Auxiliary Input Problems
Hi Guys,
I brought a Axxess AIP-GMO1-ID hooked it up to my stock gm radio with no luck. I have a 2006 full size with the Bose radio and speakers no XM Radio, No CD Changer, But I do have the gm 12 pin connector in the back of the radio. I guess first of all is this the right unit for my radio? As per the directions I hooked the red to postive and the black to ground, When I plug the ipod into the connector it charges the battery. But I cannot get the tunes from the ipod to come through the radio. Any help please!!
Ed
Hi Guys,
Ed
Do you have a new I-pod. The latest versions Classic and Nano are having a lot of compatibility problems with many after market accessories. Does Axxess specifically support the Ipod model you have? The folks with the Avics have had to drop back a level on their versions to get them to work and even than some are still having problems.
Hi Guys,
Ed
Hi Guys,
Ed
Hi Guys,
Ed
Don't know about the aip-gm01-1d unit. I've used the Soundgate AUXGMV3 and PIE GM12-AUXV2 and you need to disconnect the ground on the battery for about 30 seconds. When you rehook the battery the radio should reconize the aux units. I've installed many of these units with never a problem.
If you go this route save your money and buy the aux adapters. They work the same as the The Neucleus NC-X2i Neucleus NC-X2iLAN iPAC-OEM for less money. You'll need to buy a 3-Ft. Gold Series Stereo Y-Cable, Phono Plugs to 1/8" Jack from radio shack. Part# 42-2550
http://www.logjamelectronics.com/
Good luck
    ballencd
    ballencd
  • Who's Online   3 Members, 1 Anonymous, 664 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
