Hard Start / Kickback On 50+ Degree Days!
opry-guru
Bought a 1500L express van this winter w/5.7L that has served me well during the cold. The only problem I had when I bought it was the radiator and water pump leaks. (slow leak that loses a quart overnight and I'm topping it off every morning till I have the time to fix it)
Well things have changed now that warmer weather is coming to the beach. On nice days that seem to be in the 60's+ the van cranks but doesn't want to fire. Often it will kickback - sometimes hard enough where it stops the cranking!
Eventually with enough cranking (20+ mins worth) and pumping the gas pedal I can get it to fire - first with a slow sputter and as I pump the pedal I can increase the engine speed until something changes and it runs fine. Once it's running everything appears normal. And if I drive the van till it gets to temperature, I can shut the van off and restart it no problem.
I confidently replaced the Crank Position Sensor this morning with no luck - although it only took 2 minutes to start the van. I still had to work the pedal.
After I write this I'm going to disconnect the battery in hopes of resetting the computer. (works in fords...)
  • Sometimes I notice a slight hesistation coming off idle.
  • My perception is gas mileage has gotten a little worse.
  • There's a sweet spot on the pedal, off idle where if I hold it there during cranking the van really wants to fire over.
  • There have been warm days with cold nights where it wouldn't start at all during the day but fired right up at night.
  • The check engine light comes on after driving about 2-3 mins - was that way when I bought it.
  • Lately I notice an annoying bucking around 40-45mph after the OD has engaged and the engine rpm's are low regardless of ambient temp.
  • Normally I start the van THEN top off the coolant.
Any help is appreciated - thanks guys. ~Rich
Disconnected the battery for 2 mins - reconnected and van started right up. Don't know if that's what it needed after the CPS change - will keep you posted.
~Rich
Update - Seems to be fine!
After replacing the CPS then disconnecting the battery for 2 mins (thus resetting computer?) the van has been starting and driving no problem in warm weather.
I did have a little timing issue the first time I tried to start it after resetting the computer and some hesitation coming off idle to about midrange on the throttle but that was only on the first day of driving.
Since then, everything has been fine! Good luck with your GMs ~Rich
  • 3 weeks later...
Just an update for anyone who cares. I let the van sit for a couple of days after my successful install of the CPS during which it rained.
Next thing I know, I tried to start it and it wouldn't fire. Acted like it wanted to but wouldn't kick over. HOWEVER it wasn't giving me kickback like the old CPS sensor did.
So without looking I bought a new ignition module and installed it. Van still wouldn't fire! Instantly I check for spark from the coil wire which I got (nice and hot too!!!) So I popped open the dist cap and WHOA!!! Both cap and rotor had so much corrosion they looked like they had been sitting in salt water for years!
Put a new cap and rotor in, van fired up and everything has been perfect for a week, rain or shine! Got my gas mileage back too!
Good luck everyone! ~Rich
Actually it was the CPS because after I replaced it, the kickback stopped. However, the cap / rotor problem that came days after fixing the kickback was a seperate incident brought on by the ambient moisture.
Thanks for your sarcastic post-fix commentary but where was your enlightenment when I was struggling for the answer to my bad CPS??? ~Rich
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 423 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
