Rf Interference To The Truck
Skip Talker
Any one using big radio transmitters on their truck? I have a (cough) legal limit amplifier and can’t use it on my truck. On higher bands using over 500 watts the truck sputters, gauges jump all around and don’t think it is too good for it. On lower bands even with just 100 watts the doors lock and unlock the gauges swing back and forth and the engine cuts off.
I’ve had some improvement by disconnecting the rear window defogger. And using ferrite beads but still have some problems.
This is not a DC power starvation problem. I have a separate 300 amp alternator and its own batteries just for the amp. It is isolated from the rest of the vehicles electrical system. I can disconnect the antenna and key up into a dummy load, nearly 2,000 watts, and don’t have the problem. It’s got to be RF getting into something.
For you RF purest saying the amp is just putting out spurs, the spectral quality exceeds FCC emissions standards.
I see those CB guys running a whole lot more power and haven’t admitted to any problems.
What model vehicle is it? I've stayed away from a "foot warmer" myself for just the same reason. Mines an 06 and with the electronics on these vehicles I think it's going to be hard to isolate RF of that power with the 10+ different ECM's on some of these vehicles. Some guys around home are putting 3 and 4 grounding straps to everything (radio, aux. battery, antenna, etc.). Trying to wrap/contain high sources of RF power usaully create heat problems also. I guess that's why the FCC regulates the power (can't believe I said that). New vehicles just don't seem to be "Fire in the Wire" friendly. Good luck.
one of my friends in arkansas ...eventually had to pull most of his cb equipment out of his chevy truck ... he kept frying the ECU after a few weeks ...
there isn't much that can help it ... other then a completly isolated electrical system just for the equipment ... and get the antenna up to where the base of it is over the roof of the truck ...
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
