2004 Seirra Climate Control
jebvd
This is a 2004 seirra with dual climate control.
I have been experiancing this issue for the last month. It started as an intermitant problem, the heat would not work, if I turned the system on and off a few times the heat would start working. A week later I would have to turn the system on and off about 20 times before the heat started working, now I cant get it to work no matter how many times it is switched on and off.
I have tried two things so far, one on the advice of a local tech, I pulled the hvac controller from the dash and unplugged it for a few minutes. Thinking this would reset any hvac settings. I also disconnected the batt to hopefully accomplish the same thing.
Both times when I turned the system on it was defualted to defrost. After awhile all controles worked normall, but still no heat.
While searching this forum I have not found this same problem, It seems that most hvac issues are a problem with one side which could be a blend door actuator. I have no heat from either side, could both blend door motors be bad?
One other thing I noticed, in auto mode, when I turn it on, the A/C (snow flake) is on the control panel. It doesnt matter what I have the temp set on. I dont know if this is normall because I usually use manual control. Is their a cabin temp sensor that could be bad?
Thanks for any and all help!
Well if both actuators are bad it would blow heat all the time, if you take the passenger actuator off you can move the butterfly to the open position and see if your getting heat. If not, then I'd say the heater core is bad.
To take the actuator off you need to remove the duct work from the passenger side footwell, don't remove the screw from the center console the whole way or you'll never get it back in. The actuator is up front has a small set of wires hooked to it and looks like a small piano. Before you unplug it turn the temperature to 60 then unplug the actuator and unscrew it from the duct work. You can move the butterfly (square peg) to the open position and that should let heat in or vise versa, I can't remember, either way with the temp on 60 you'll get heat by moving the butterfly if the core is working. Whatever you do don't operate the actuator unbolted from the duct work. You'll over travel the unit and it won't work correctly. Also note you must return the temperature to the same degree that you had when you took the actuator off, if not the system won't work correctly.
Your snowflake (a/c) should be on no matter what the cab temp or setting is, as long as the outside temperature is ~36 or above.
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,365 Guests (See full list)
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
