Gm Major Guard Protection Plan 4wd
I have a 2008 GMC 2500 HD SLT Extended Diesel with all factory options. Is it worth it to purchase the following GM protection plan. I undertand the Diesel drive train is good, the issue seems to be having electronics coverage. Is this plan needed. How is reliability.
GM Major Guard Protection Plan 4WD
Deductibles $0 $100 $200
72 month/100,000 miles $2085 (1885 cost) $1720 $1455
I'll do it for $1985.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
