Leveling A 2006 Gmc
Just crank the torsion bars no more than 1.5". Should get you pretty close to level. If you crank more, the ride will really start to suffer, and you'll start wearing out suspension components faster.
EDIT: If you adjust anything with the front suspension, make sure you get an alignment.
You could also take the blocks out from under the rear leaf springs, but I doubt you'd want to lower a 4x4.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
