Piston Slap? Do You Have It?
2003 GMC SIERRA 1500 V6 4.3L 43000 MILES
Well about 1 1/2 months ago all of a sudden one day my truck starting making this really loud sound. Kinda sounded like a Mack Truck. :D
As soon as i heard the sound i thought that i had broken something, a lifter or a rod. But after 4-5 min it would all of a sudden go away. Some days it lasts only a couple of seconds other days i last for minutes, or until i start driving it for a couple of minuets.(i also noted that while i was experiencing this noise, my oil pressure would be pegged to the top and after the sound went away, the oil pressure would return to normal) On top of this about 1 week ago, within 2-3 day time period, I lost 1 1/2 gallons of radiator fluid! i checked the trucks for any leaks and found non. I had never had any problems with this, So i assumed the worst, that it is leaking water in to the engine. So i dumped a little oil out of the pan and found non. Where did the water go?
Anyways I just took my truck to the dealer ship over this, the gm guy heard the engine knocking sound and said it might be piston slap. Well they are going to keep it over night and they are going to check it out, ill keep ya ll posted on what happens. :chevy:
*****VIDEO CLIP OF THE ENGINE NOISE BELOW*****
Hmmm......sounds like piston slap.
My truck has had it for several years now, doesn't seem to affect anything (I hope).
but I don't hear it at idle, only under load and usually only for the first minute or so.
I use an auto-starter to start up the truck just before I go out. Then I can get in and drive and not worry.
I have to say, when most prople mention they have piston slap I used to laugh because usually it is a minor tick for a handfull of seconds. But yours is LOUD, that sounds like crap. I'd pull it and put in a 6.0 LQ9.........
****UPDATE****
Well the Gm guy told me I have a INTAKE GASKET LEAKING, and that the radiator coolant was mixing in with the LIFTERS. That is why it was making that taping sound. States they are going to replace the Intake Gasket and Replace the lifters.
Hopefully this will resolve this issue.
My 01 had the piston slap, but I'd definitely agree that yours is much louder than mine. I hated that noise.. made me feel like I was driving a piece of junk.. when in reality I had a very nice truck. I just made sure to let it warm up and stop before I moved it.
Yeah, I have it on my '01 5.7 Silverado when I first start it up. My understanding was that this is fairly common for certain year trucks. Wasn't there a lawsuit or something filed against GM for this????
YES THERE HAVE BEEN SEVERAL. EITHER THEY FIX THE ISSUE, GIVE YOU EXTENDED WARR, INSTALL A NEW RE CERTIFIED ENGINE, OR BUY BACK THE VEHICLE. SUPPOSABLE A TRUCK WITH THIS PARTICULAR ISSUE LOOSED ITS TRADE-IN VALUE, OR SOME PLACES WONT EVEN TRADE IT IN IF THEY KNOW YOU HAVE THIS ISSUE.
www.pistonslap.com
    FiLo
    FiLo
  • Who's Online   4 Members, 0 Anonymous, 542 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
