"reduced Engine Power"
ufalufa
Hi, I have a 2001 Chevy Suburban 1500 2wd. I recently seen this in my message center and the check engine light popped on right after, the RPM reved to about 2,000 and there also was a power loss, the code mentioned something about the throttle positon sensor being out of range. What would cause this? I have also been experiencing to me seems like a power surge the traction control lights blink off and on and the truck becomes sluggish would this be caused by the Reduced Engine Power problem?
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 463 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
