Good Torsion Bar, Bad Torsion Bar....
Hi folks, just a quick torsion bar question for an 02 Suburban 1500.
Bought this 'Burb used and it's been a gem, but it's time for some suspension mods. It sits stock, but the drivers side key is adjusted up near the limit, while the passenger side key has been lowered near it's limit to get it level. I'm guessing this is happening because the drivers side bar is sagging.
The part number on the bars read 'XK', which is the lowest torque rated bars according to the GM Torsion Bar 401 site. http://www.offroad-tech.com/tech/tb401/
I'd like to adjust the bars up a little to clear slightly larger tires, but the current driver side bar is already near max.
1: Should I install a new drivers side torsion bar hoping it better matches the original passenger bar ?
2: Should I just replace both at the same time ?
3: Should I go to a heavier rated bar on both sides to gain a little lift/firmer ride ?
The Torsion Bar 401 site lists 13 different GM torsion bars, I'm kind of surprised this heavy vehicle has the lightest rated bars. Explains the soft ride, almost too soft for my taste.
Thanks for any help!
-Ron
changing the torsion bar settings will beat the heck out of the front end moving parts over time, unless some good resets all the alaignment setting for the new height
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
