Steering Column Cover Removal
lan2402000
I have always had luck applying downward pressure in the turn lever hole and working the cover around from there after removing the screws in the bottom if any. just make sure the temp is warm as the cover will need to flex. Then, a E6 torx to remove the upper trim pieces. The manual says to remove the steering wheel. This would make it easier if you choose. Good Luck!
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 759 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
