Buy Exhaust Or Cut Off Stock Muffler
I was looking into buying a Magnaflow XL Series 4" turbo back exhaust to put on my Dmax and I was talking to a couple of people and they said that its the same as cutting out the stock muffler and putting in a straight pipe or a flow through muffler. Would it make that much difference to put the magnaflow system on over just putting a flow through muffler on? Sound is not an issue, its the benefits to the engine I'm looking for.
Yeah straight pipe it, it'll sound awesome. Or if you need a turbo-back system, MBRP is the only kit worth buying.
Why is that?
Nothing sounds WORSE than a diesel or a V-10 with a set of aftermarket exaust !
V-8 gassers are ok is some cases.
My fellow plow guys have nothing but problems with complaints from customers
about their window shaking exaust noise rigs at 4 am while plowing their
driveways....................
Spendy your money better and get a PCM tune!
Why is that?
MBRP makes the only good sounding exhaust for Diesels, If there was a runner up I would say it would be Banks, but MBRP sounds awesome.
I can agree with the noise for plowing early in the morning. I would leave it stock if that's what I did with my truck.
I use mine for towing and daily commute to work. I had the muffler cut out and replaced with stainless pipe, then a 4" stainless tip. The noise isn't bad at all in the cab until you get the rpms up. That is normally when you are going much above the speed limits.
I could get a sound clip, but it may be a tad different, being mine has no cat. converter.
Also, I feel good towing when I know my egt's will stay lower with a free flowing exhaust.
I'm not plowing with this truck. She's my daily driver and tow vehicle. I don't have a cat either, straight back from the turbo downpipe to the muffler. I still have the LB7 not the LLY. How much lower on the EGT's?
I don't have an EGT guage, so I don't know first hand. I have seen many other posts where people have one and straight pipe and they stay considerably lower. I can't remember the exact numbers.
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 619 Guests (See full list)
