I need to know which AC Delco transmission filter to order for my 2005 Yukon XL.
On RockAuto I see two possibilities,
AC Delco - part #24210956 (for the MT1 Transmission) and
AC-Delco part # T339(24227080) (for the M33)
Is there a number or tag somewhere on the transmission that will tell me, or is one of the numbers in the glove box the key ?
Any help here will be appreciated
Yep,The MT1 or M33 is the RPO code.
Look in your glovebox for yours.
Thanks,
I found M30 code in the glove box. Looks like the RockAuto didnt even have the M30 RPO option listed.
The correct ACDelco # appears to be 24208576.
Thanks,
Yep,thats it,I wasn't sure of the model of Yukon you had (1/2-ton,3/4-ton,Denali,non-Denali) but regular 1/2-ton Yukon's (Non-Denali's) have the M30 tranny.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
