Windsheild Washer Problems
i have a 1992 GMC Sonoma and when i hit the washer buton the wipers move but no fluid comes out. I think the switch might be bad. i was woundering if enyone had simular problems?
  • 3 weeks later...
Guest Riggs
100% has to be a Wiper Pulse Module.... Advanced auto has it for like 15 Bucks
:cool: Pretty sure Riggs is right. I had a similar situation, and that was the culprit. Just be careful you don't crack the resivour when your removing the motor.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
