Fan Clutch
cao88c
Hey guys,
I'm replacing the water pump on my 1999 suburban (5.7). I cannot for the life of me get the fan clutch nut out. I am using a fan wrench. Is there a trick to this or what?
I use an air chisel on the stubborn ones.
Being that I don't own an air chisel, I got a BFG (big f---in hammer) and showed that nut who's boss! Thanks!
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,133 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
