W4m Just Installed Have Questions.
Thanks for reading,
I just installed my tune and 4 things happened, the change engine oil light came on, the speedo is off, the brakes light came on , the ABS light also came on, I have not had it relearned yet, I can do that tomorrow, just wondering if this is normal?? Will the re-learn help these problems, any suggestions?? thanks aalllot.
Nope, that's not normal. Sounds like they probably sent you the wrong tuned PCM or something? I'd throw the stock PCM back in and call Jesse to get it fixed.
Thanks for reading,
your ABS and brake light and speedo is probably because it isnt tuned for the right gear in the rearend so your ABS sensors are reading a different speed than your driveshaft speed (or speedo) and it will shut your ABS off and throw all kinds of warnings at you...i know this because i just swapped gears in my truck and it did that. you could just reset the change oil light...i would definitely call jesse. he either sent you the wrong PCM or tuned it for the wrong gear on accident.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 224 Guests (See full list)
