Extang Vs Lund
Which tonneau is better? Lund Genesis Tri fold or Extang Trifecta.
If you have one of these could you please post pictures of the installed cover and your opinion on the cover.
Thanks
I bought a Trifecta a couple months ago and so far I like it. It has a bulb seal that was too thick for the tailgate spoiler so I replaced it with the seal from an Extang Blackmax tonneau and it works much better.
Here's the only picture of the installed cover that I have.
It's my understanding that the covers are substantially similar but the attachment mechanism is slightly different. I like the Lund lever cam-locks because they make it easy to attach and remove the cover.
I didn't have any issues with quality - I broke a hinge once and I got a new one for free from Lund, no questions asked.
Nothing to say about the Extang either way, since I have never owned one.
I like my Extang alot, havn't had any leakage issues at all, and folds up quickly for when i need to have access to the bed or to remove it.
I initially thought the fact of having 4 quick cam releases would be great until one day after going down a rough road, or me just not verifying that it latched correctly i had one of my rear latches come loose and the end of the cover was flapping alot. I think that if the front latches were not wingnut like screw latches that the whole cover would of come off.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
