Anybody Running Nitto Terra Grapplers?
hey guys, well i got some new 265 nitto terra grapplers yesterday and i was just wondering what you guys that have them run for psi? i want a compfortable ride and i also wanna save as much tread as possible!!!
thanks in advance for your help! :lol:
steve
I'm running mine (285/65R18) at about 48-49 PSI at the moment, but I think that's a bit high. I am going to run them about 42-45 PSI and see how that feels. They are a bit stiff right now.
I had to drop my 285's down to around 32 PSI due to the rim width squeezing the tire and reducing the contact patch...Until I got aftermarket rims...But I still never kept them over 35 PSI due to a harsh ride.
I am running 275/60R20's. I have personally found that running them just under 45 PSI seems to provide the best ride and should be enough pressure to save tread.
that sounded kinda high to me??? Maybe I dont have enough air in my tires??? I'm running 38 psi...the tire says 42 psi max cold.....what does he nitto's say????
Your tires have air in them?? :)
I run my 305/50/20s at 40-42 cold.
I was running 36-38 cold but the overall feel wasn't right for me. My gas mileage went up by 1/2 a MPG (according to the DIC) when I switched to the higher pressures. I run 38 cold on my 99 with 265/70/17 Firestone Destination AT.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 929 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
