Truck Wont Turn Over
this is on a 99 NBS truck. Went to gas station, went in paid, came out went to start truck turned over fine for a sec then nothing at all. so i tried again, now nothing happens at all, I can hear the relays clicking under the hood. Had wife come up and jump start it with her car, nothing but that click in relay....went under truck and hit the starter with a hammer would hear a loud click(and could feel it if hand was on starter), then nothing.
Any idea on what the hell is wrong? Starter bad? something else bad. seems as the starting electronics is fine since i can hear the start click under truck,
thanks
thanks
Sounds like the starter went bad. The hammer trick does not always work. Have your battery tested. If it tests good, then I would get a new started, and replace it. You can also get the old starter tested at places like autozone. Good luck.
-Al
The newer starters use permanent magnets. You don't want to hit them with a hammer because you may end up breaking the starter even further.
I would get your battery tested, but it doesn't sound like the battery if you tried to jump it an it didn't start. Most likely you have a bad starter.
I would say test the battery... I had the same thing happen last week. I tried to start, nothing... It wouldn't even take a jump, but I the electronics were working.
I changed the battery and it started right up.
I don't see it being a fuel pump problem, if that were the case it would at least turn over. Ditto on the starter, just yank it out and take it a local parts store and have it tested.
  • 3 months later...
    bellssn690
    bellssn690
  • Who's Online   0 Members, 0 Anonymous, 815 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
