2000 Silverado Pinion Shaft Gears
KDML
I needed to remove the rear axles from my 2000 Silverado 1500 to replace the rusted out brake dust shields. When I was replacing one of the axles I spun the axle knocking out of place the two small gears,in the center of the carrier, which the pinion shaft slides through.
Is there any special way to line these up when I put them back or can they go back in any way?
Thanks
Doug
Those would be the spider gears it will be ok to put them back in they have no special place all 4 are the same they should have spacers/bushings behind them.
Thanks
That's what I thought - just didn't want to create a future project for myself
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 842 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
