Gmpp Dual Rear Exit Performance Exhaust Clearance
Chevy2k5
Will the GMPP dual rear exit performance exhaust system fit with both the spare tire and factory hitch? I have a 2003 Silverado extended cab and it's GM PART # 17802152 if that's any help.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
