Electrical Failure 99 Suburban
grunion0
I have a 99 suburban with 170K and everything was working fine. I drove it to the store and after 5 minutes got back in and it would not start. The radio and ignition sound came on like normal but when cranking the engine everything went dead.
Symptoms:
Turn ignition on and the standard beep sounds and gauges seem to work but then…
1) Turn lights on and beeps stops and gauges go dead except the fuel gauge does a 180 completely off the chart.
2) Turn hazards on and a very weird sound comes from under the hood like a unlubricated wind up toy. No flashing just a very dim glow. Gauges go dead except the fuel gauge does a 180 completely off the chart.
3) After charging for a long time and turning the key to aux I finally got the windows to roll up without the same gauge and seemingly short effect.
4) Blinkers cause the gauges go dead and the fuel gauge does a 180 completely off the chart as usual.
5) Car will not start or turn over. It’s like there is an automatic short that is stealing power.
6) Interior light will come on dimmer than usual when key is in aux position.
Things I have checked:
1) Fuses all check out and look clean.
2) Battery checks out. Had it load tested at AutoZone.
3) No visible signs of burned wiring or lose connection. No burned smells.
4) Disconnected the amp and stereo which is on a separate circuit I installed myself to no avail.
5) Pulled every fuse while the hazards were on hoping there would be a change and help identify a bad circuit but no luck.
6) Disconnected the ECM and it did not change the situation.
I have a general mechanic background and have worked on my own cars all my life but not professionally. I just recently (about 6 months ago) replaced the intake manifold gasket. I have an electrical background and can follow any advice in that aspect or would like to think so. I am at a complete and utter loss here. I really have no idea what to do next other than start dismantling the components and doing ohm test but still would not know if the values I am looking at are within range or not.
Any advice that ANYONE can give me would help me greatly. This is our main source of transportation and is dire for it to be working again.
I have spent some time at our shop discussing this issue with various mechanics and have recieved a few different opinions. One thing I should point out is when I disconnected the battery and reconnected it, it did not spark or arch like there was a load on it. (actually not at all)
1) The voltage is being disrupted either by a corrosion or a loose connection in such a way that any load kills the circuit like a circuit braker also known as a ghost voltage.
2) See if arching the starter will allow it to turn over. (Although I see this as tough considering the location) If it does not check the battery terminations.
Thats all I got for now. Once I get home at 5pm I will tinker with it some more. I can say that these things do not make sense as this happened instantly like a component went bad but I am will to try anything. This is not an intermitant problem so it should not be that hard to find......at least I hope.
Ok, after I got home from work I did some poking around. I bypassed the starter and the altenator and everything was good until....I got to the fuse box. Doing a continuity test from fuse to fuse from the main entry terminal at the front of the fuse box for reference I found that the ECM fuse did not have continuity. I pulled the fuse out and checked the contacts and tested. From one side of the fuse to the other it registers for a split second and then goes open. I have no voltage running through the system and I am using the tone testing mode with my fluke meter.
After further checking I have found that with the ECM umplugged and checking the resistance between the two fuse contacts between the fuse block, I get a reading of 11K ohms. I believe my fuse block is the problematic peice of this puzzle. I will update my final findings later. If not for anything else... maybe for the search engines to help someone later with a similar problem. :lol:
Well someone has got to do it. I am that guy.
Any advice would be helpfull but I fear I will have solved the problem before I get what I came here looking for.
Ok, its another day and I am back at it. I left off with the ecm fuse in the fuse block under the hood. Checking the two fuse contacts for the ecm fuse (with the fuse pulled out of course) I am getting a reading of 11K ohms. This should be open with no reading as the fuse should be the only path for voltage to pass but it is getting around this circuit somehow and giving me a reading. I am at a loss. I guess I will attack the ignition switch next.
I admire your persistance. I sure hope you get it figured out. I tend to stay away from electical problems myself. I always wind up getting flustered. :lol:
After getting into the steering collumn and ignition switch I stopped and started thinking (something I rarely do :lol: ) "Maybe, just maybe I am making this more complicated than it actually is"...I turned the hazzards on and touched the newly terminated batter cables on the (TOP) posts instead of the (SIDE) and it immediately started working. Autozone load tested the wrong damn posts on the battery and they even asked me which ones I used for my car. The side posts have a dead cell which was causing the issue. I bought a new battery and put my car back together and everything is good. I feel like a donkey.
The side terminals on the battery will seperate from the internals of the battery itself, usually on the positive side. I've seen several just fall loose from the battery while connected to the cable. Overtightening the cables is usually the cause, or sometimes just age.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,262 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
