Emergency Flasher Button Will Not Work
I have the obs pickup, 2000 model
The emergency flasher button will not work,
You push it down and it's suspose to pop up and the flashers start working.
you can push the button down but it will not pop up to the on position.
Think a little wd-40 would help it or other material? May have dirt and stuff in switch as they mounted switch on top of steering column and I do not spend a lot of time cleaning the old work truck, if you know what I mean.
If lube would not work, has anyone ever changed this switch?
Thanks for your assistance as I need the flashers from time to time in my work. Must get it fixed.
If you checked the fuse and it looks good, make sure to check the flasher:
gmLogoFlat.gif Service Information
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 786377 Hazard and Turn Signal Flasher Replacement
Removal Procedure
  1. Remove the knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gages and Console.
  2. On the back side of the fuse block release the retainer while pulling the flasher (1) outwards.
  3. Remove the flasher (1) from the fuse block.
Installation Procedure
tif.gifInstall the flasher (1) to the fuse block until the retainer clicks into place.
Install the knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gages and Console.
© 2008 General Motors Corporation. All rights reserved.
If you want to go straight to the switch replacement, here is the necessary information on how to replace the switch...:
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 449511 Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle
Removal Procedure
  2. Ensure the lever is in the center or the OFF position.Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
  3. Disconnect the negative battery cable.
  4. Disable the supplemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
  5. Remove the inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  6. Remove the horn switch. Refer to Horn Switch Replacement - On Vehicle .
  7. Remove the tilt lever. Refer to Tilt Lever Replacement - On Vehicle .
  8. Remove the steering wheel. Refer to Steering Wheel Replacement .
  9. Remove the knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gauges and Console.
  10. Loosen the steering column bracket nuts.
  11. Remove the 2 TORX® head screws from the lower column cover.
  12. Tilt the cover down. Slide the cover back in order to disengage the locking tabs.
  13. Remove the lower column cover.
  14. Remove the TORX® head screw from the upper column cover.
  15. Remove the upper column cover.
  16. Remove the 2 wire harness straps from the steering column wire harness.
  17. Remove the connector position assurance (CPA) retainer from the brake transmission shift interlock.
  18. Disconnect the steering column bulkhead connector from the vehicle wire harness.
  19. Disconnect the gray and the black connectors of the switch from the column bulkhead connector.
  20. Remove the 2 TORX® head screws from the switch.
  21. Remove the multifunction turn signal/hazard switch.
  2. Install the multifunction turn signal/hazard switch.
    Use a small blade screwdriver in order to compress the electrical contact.
    Move the multifunction switch into the position.
    Ensure the electrical contact rests on the canceling cam assembly.
    Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  3. Install the 2 TORX® head screws on the switch.Tighten
    Tighten the screws to 6 N·m (53 lb in).
  4. Install the connectors of the switch to the column bulkhead connector.
  5. Install the steering column bulkhead connector to the vehicle wire harness.
  6. Install the connector and the connector position assurance (CPA) retainer to the brake transmission shift interlock.
  7. Install the 2 wire straps on the steering column wire harness.
  8. Install the upper column cover.
  9. Install the steering column bracket nuts.Tighten
    Tighten the nuts to 30 N·m (22 lb ft).
  10. Install the knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gauges and Console.
  11. Install the TORX® head screw to the upper column cover.Tighten
    Tighten the screw to 1.5 N·m (15 lb in).
  12. Install the lower column cover.
  13. Install the 2 TORX® head screws to the lower column cover.Tighten
    Tighten the screws to 3 N·m (25 lb in).
  14. Ensure the lever is in the center or the OFF position.
  15. Install the steering wheel onto the steering shaft. Refer to Steering Wheel Replacement .
  16. Install the horn switch. Refer to Horn Switch Replacement - On Vehicle .
  17. Install the inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  18. Install the tilt lever. Refer to Tilt Lever Replacement - On Vehicle .
  19. Enable the SIR system. Refer to Enabling the SIR System in SIR.
  20. Connect the negative battery cable. Perform the Idle Learn Procedure for 4.8L, 5.3L and 6.0L engines only. Refer to PCM Idle Learn Procedure in Engine Controls-4.8L, 5.3L and 6.0L.
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 512849 Disabling the SIR System
  1. Turn the steering wheel so that the vehicle's wheels are pointing straight ahead.
  2. Turn OFF the ignition.
  3. Remove the key from the ignition switch.Important: With the AIR BAG fuse removed and the ignition switch in the RUN position, The AIR BAG warning lamp illuminates. This is normal operation, and does not indicate an SIR system malfunction.
  4. Remove the AIR BAG Fuse from the fuse block.
  5. Remove the connector position assurance (CPA) (1) from the driver yellow 2-way connector (2) located at the base of the steering column.
  6. Disconnect the driver yellow 2-way connector (2) located at the base of the steering column.
  7. Access the IP module yellow 2-way connector (1) located behind the main IP support by opening the glove box and pressing in on the sides. This will allow the glove box to extend beyond the stops and to fully open. The IP module connector will be attached to the main IP support.
  8. Remove the CPA from the IP module yellow 2-way connector (1) located behind the IP support.
  9. Disconnect the IP module yellow 2-way connector (1) located behind the IP support.
  10. Remove the connector position assurance (CPA) from the driver side air bag yellow 2-way connector (2) located under the driver seat.
  11. Disconnect the driver side air bag yellow 2-way connector (1) located under the driver seat.
  12. Remove the connector position assurance (CPA) from the passenger side air bag yellow 2-way connector (2) located under the passenger seat.
  13. Disconnect the passenger side air bag yellow 2-way connector (1) located under the passenger seat.
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 449521 Horn Switch Replacement - On Vehicle
Removal Procedure
  1. Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
  2. Disconnect the negative battery cable.
  3. Disable the supplemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
  4. Remove the inflator restraint module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  5. Remove the horn contact from the steering column.
  6. Remove the 4 TORX® head screws from the 2 contact plates.
  7. Remove the 2 contact plates from the steering column.
  2. Install the 2 contact plates to the steering column.Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  3. Install the 4 TORX® head screws in order to secure the 2 contact plates to the steering column.Tighten
    Tighten the screws to 3 N·m (53 lb in).
  4. Install the horn contact to the steering column.
  5. Install the inflator module to the steering wheel. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  6. Enable the supplemental inflatable restraint (SIR) system. Refer to plemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
  7. Connect the negative battery cable.Perform the idle learn procedure for 4.8L, 5.3L and 6.0L engines only. Refer to PCM Idle Learn Procedure in Engine Controls-4.8L, 5.3L. 6.0L.
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 513366 Inflatable Restraint Steering Wheel Module Replacement
Removal Procedure
Caution: This vehicle is equipped with a Supplemental Inflatable Restraint (SIR) System. Failure to follow the correct procedure could cause the following conditions:
Air bag deployment
Personal injury
Unnecessary SIR system repairs
In order to avoid the above conditions, observe the following guidelines:
Refer to SIR Component Views in order to determine if you are performing service on or near the SIR components or the SIR wiring.
If you are performing service on or near the SIR components or the SIR wiring, disable the SIR system. Refer to Disabling the SIR System.
  1. Disable the SIR system. Refer to Disabling the SIR System .
  2. Turn ON the ignition.
  3. Turn the steering wheel 90 degrees so the side of the SIR module is at the 12 o'clock position in order to gain access to the holes behind the steering wheel.
  4. Insert a screwdriver into the access hole and push the leaf spring to release the notched pin that retains the inflator module.
  5. Turn the steering wheel 180 degrees in order to gain access to the remaining hole.
  6. Insert a flat-bladed tool into the remaining access hole and push the leaf spring to release the notched pin that retains the inflator module.
  7. Tilt the top of the inflator module rearward to gain access to the SIR wiring.
  8. Disconnect the SIR lead wire from the clip on the inflator module.
  9. Disconnect the SIR lead wire from the clip on the steering wheel.
  10. Disconnect the connector position assurance (CPA) retainer from the SIR connector.
  11. Disconnect the SIR connector.Caution: When carrying a live inflator module, make sure the bag opening is pointed away from you. This minimizes the chance of injury in the case of an accidental deployment. Never carry the inflator module by the wires. Never carry the inflator module by the connector on the underside of the module.
    Make sure that the bag and trim cover are facing up whenever you place a live inflator module on any surface. This is necessary to provide a free space for the bag to expand in the unlikely event of accidental deployment. Never rest the steering column assembly on the steering wheel with the inflator module face down, and the column vertical. This may result in personal injury.
  12. Remove the inflator module.
  13. Fully deploy the module before disposal. If the module was replaced under warranty, fully deploy and dispose of the module after the required retention period. Refer to Inflator Module Handling, Shipping, and Scrapping .
  2. Connect the SIR connector.
  3. Connect the CPA retainer to the SIR connector.
  4. Install the SIR lead wire to the clip on the steering wheel.Important: Verify that the wiring is not exposed or trapped between the inflatable restraint steering wheel module and the steering wheel.
  5. Install the SIR lead wire to the clip on the inflator module.
  6. Press the inflator module into the steering wheel firmly enough that the module engages and latches the notched pins in the leaf springs.
  7. Rotate the steering wheel back into the straight position.
  8. Enable the SIR system. Refer to Enabling the SIR System .
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 449519 Tilt Lever Replacement - On Vehicle
Removal Procedure
Pull the lever out of the steering column.
  2. Align the lever in the steering column.
  3. Push the lever into the steering column.
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 449523 Steering Wheel Replacement
Removal Procedure
Tools Required
J 1859-A Steering Wheel Puller
  3. Disable the supplemental inflatable restraint (SIR) system. Refer to plemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
  4. Remove the inflator module. Refer to plemental inflatable restraint (SIR) system. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  5. Remove the horn switch. Refer to Horn Switch Replacement - On Vehicle .
  6. Make an alignment mark in order to note the relationship of the steering wheel to the steering shaft.
  7. Remove the steering wheel nut.
  8. Remove the steering wheel, using the J 1859-A .
  1. Align the marks made during the removal procedure on the steering shaft and the steering wheel.
  2. Install the steering wheel onto the steering shaft.Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  3. Install the steering wheel nut to the steering shaft.Tighten
    Tighten the nut to 40 N·m (29 lb ft).
  4. Install the horn switch. Refer to Horn Switch Replacement - On Vehicle .
  5. Install the inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  6. Enable the SIR system. Refer to Disabling the SIR System in SIR.
  7. Connect the negative battery cable.Perform the Idle Learn Procedure for 4.8L, 5.3L and 6.0L engines only. Refer to PCM Idle Learn Procedure in Engine Controls-4.8L, 5.3L and 6.0L.
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 445210 Knee Bolster Replacement (Non-Luxury)
Removal Procedure
  2. Remove the IP cluster trim plate bezel. Refer to Instrument Panel Cluster Trim Plate Bezel Replacement .
  3. Remove the knee bolster screws.
  4. Unsnap the top of the knee bolster from the IP assembly.
  1. Notice: Refer to
Fastener Notice in the Preface section.
Snap the top of the knee bolster into the IP assembly.
Install the knee bolster screws.Tighten
Tighten the screws to 2 N·m (18 lb in).
Install the IP cluster trim plate bezel. Refer to Instrument Panel Cluster Trim Plate Bezel Replacement .
2000 Chevrolet Chevy C Silverado - 2WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 445211 Instrument Panel Cluster Trim Plate Bezel Replacement
Removal Procedure
  1. Apply the parking brake to prevent the vehicle from moving.
  2. Move the shift lever all the way down (if the transmission is automatic).
  3. Tilt the steering wheel to the full down position.
  4. Pull gently rearward on the retaining clips holding the bezel to the instrument panel (IP) assembly.
  5. Remove the bezel.
  2. Position the bezel to the IP assembly.
  3. Align the guide pins and the retainers with the holes in the IP assembly.
  4. Apply pressure to the bezel in the area of the retainer clips in order to engage the clips to the IP assembly.
  5. Tilt the steering wheel to the normal drive position.
  6. Move the shift lever to the park position (if the transmission is automatic).
  7. Disengage the parking brake.
Hope this helps, I would check the fuse first and see if that is busted, and then check the Flasher under the Knee Bolster panel, if those are in good working order, then you will have to disassemble the steering column (and airbag) to get to the switch.....a note, none of the hyperlinks will work, but I have posted all of the relevent information onto your thread regarding each repair (Fuse, Flasher, Hazard Switch Replacement)
