96 S-10 Ac Issues
Newgmer
96 S-10 with 120k. Well maintained. No recent engine work. Vehicle AC has not worked in years.
I have recently acquired this vehicle and I am trying to repair the little nagging problems it has. AC is my latest challenge. Here is what I know.
Using the controls on the dash I know that the ventalation system works. Vacuum is changing vents and air is coming out the right vents. Heat does work correctly. AC Compressor will not engage though.
Thinking that the AC has a leak and no refrigerant I bought a recharge kit with a guage on it. I start the vehicle and attach the guage. System reads about 35psi. On the kit is says this is a Green area and acceptable.
I decide to add some refrigerant anyway. I add a little too much and get it near 45psi. The compressor kicks on and begins to cycle on and off. It goes on when the pressure reaches 45psi and then goes off when the pressure drops back to around 20psi which takes just a few seconds. Since 45psi is the 'yellow' area I let out some of the refrigerant so that the compressor stops cycling.
So at this point I know I have a good charge and a compressor that will engage. So I start poking around online and find a site that suggests some test you can do. I figure out that the accumulator has a sensor on it that acts as a low pressure switch. I remove the connector and short the to wires. The compressor kicks on and stays on, however the AC never gets cold.
So I have a compressor that somehow seems to be functioning enough to affect the pressure in the system, but I have to short the low pressure switch to get the compressor to engage. The system appears to be fully charged, but generates no cold air when forced to run.
Anyone out there than can make some suggestions on what else I can do to locate the problem?
Mark
To start off from what you just stated. The system is low on freon. When you added freon it started to working kicking on and off which is good. You need to get the pressures on the guage up around 50-60 don't worry about the colors on the gauge. When you add freon make sure you have the truck running with the ac on. When you add freon you will notice the compressor to stay on longer. You will see on the guage that when the compressor goes off th pressure will go up around 60 psi then the compressor will kick on and go down to 20 psi then kick off. If the compressor does not kick off and stays around 30-35 psi idle the truck up and see if it kicks off. If it does then you should be good to go.
Ah so the pressure measurement is only valid when the compressor is engaged and running? It's ok to be much higher when the compressor is disengaged?
BTW thanks for your response.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
