Tail Light Bulbs
I have a new pair of clear OEM tail lights. SHould I buy the red colored glass 3157's or LED replacemets for my lights? I don't want electrical issues if I switch to LED', so anyone with advice please help.
Josh
Don't know the vehicle laws in FL., but here in LA, you must have red rear facing lights.
As for the incandescent vs LED, it will be you preference. If you choose LED you will need a new relay or place a resistor in line to adapt to the new current draw.
Well if I understood it right when it was told to me, even in LA, all you need is for the end result to be red, whether that be the bulb being white and the glass red, or the light red and the glass clear. I could be wrong, because the person that told me that is a known :D spewer, and it has been a few years since I was told this.
As for the look of the lights, I say go with some kind of colored glass. LEDs just look too ricer for me.
I was thinking along those lines also. The lights I bought for $10 are the older OEM tail light style from the 99-03 trucks. You won't be able to see any LED look if I get the LED's, I just didn't know if they would actually be any brighter than the colored glass or even the chromeed-over red glass bulbs. I just want my lights to be as bright and as red as factory or better.
Also, the good news is the lights I purchased have a red reflector section at the bottom, so hopefully I won't get hassled about the rest of it being clear.
RS 32:304
Tail lamps
A. Every motor vehicle, trailer, semi-trailer and pole trailer and any other vehicle which is being drawn at the end of a train of vehicles, shall be equipped with at least one tail lamp mounted on the rear, which, when lighted as required in R.S. 32:301, shall emit a red light plainly visible from a distance of one thousand feet to the rear, provided that in the case of a train of vehicles only the tail lamps on the rearmost vehicle need actually be seen from the distance specified. Every vehicle or trailer listed in this Subsection, other than a motorcycle or motor driven cycle registered in this state and manufactured or assembled after December 31, 1962, shall be equipped with at least two tail lamps mounted on the rear, on the same level and as widely spaced laterally as practicable, which, when lighted as herein required, shall comply with the provisions of this Section.
Can we install a new flasher unit to control the new load produced by led light bulbs? I don't know if I could install a correctly designed flasher for turn signal LEDs or if I have to install the load resistors on each light I install.
If I can just install a turn signal flasher unit that will probably be easier and cheaper, so which flasher does my truck use and where is it? Iooked for it last night but couldn't find it easily on the interior fuse box.
I tried some of the after market LED bulbs and was not happy with the result. Unfortunately, the majority of the lens / reflector designs are optimized for the placement of a standard bulb with filament and the sturture of the LED bulbs prevents some light traveling back toward the bulb base that is normally reflceted. I found that the LED bulbs installed in my 2001 Sierra (stock rear lens assemblies) did not generate a very bright light in either running or brake state and in fact it was difficult to distinguish between the two states. I tried both red and white LED bulbs, noting that I did this several years ago. I ended up back to standard bulbs.
  • 1 month later...
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
