Bosch Platinum 4
ithaca
I just put them in my 2005 Z-71 and the engine seems to idle a little rougher. Can these not be used I have used them in a car of mine and they work great. The truck has 53,000 on it and I would not have replaced if it had not been for them working so well in the other vehicle. Thanks
Some other guys might disagree with me but I think they aren't that good. My brother-in-law bought them for his burb and it ran like crap, I told him to stick with delco, ngk, or autolite. I've heard other stories about people putting them in and the engine runs/idles a little rougher. it seems most guys on here use AC Delco. :D
What did you set the gap to?
you beat me to it. sounds like you don't have them gapped properly.
You don't gap the Bosch Platinum +2s or +4s. You only have to gap a standard plug.
On a second note, did you replace the wires at the same time. It takes more spark to make these plugs fire the same as a single IMO. I had the +2s on my 98 and it did run crappy til I put some MSD 8mm wires on it. After new wires it ran alot better.
Another gimmick plug I see.....I had the same kind of issues when giving the iridiums a try. From now on it's NGK TR55's and nothing else....
I use the TR55GP in my '02 6.0 and they work great.
Yea after that I learned that if the vehicle isn't high performance with a bunch of ignition mods don't bother with fancy plugs.
