Vin Check Please?
GM Vehicle Inquiry System
Summary
VIN : 1GKFK16R9VJ752947
VEHICLE INFORMATION
Merchandising Model : TK10906 -1997 SUBURBAN 4WD
Warranty Start Date : 01/15/1998
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
DAN WOLF PONTIAC AND GMC TRUCK, INC.
6060 S LA GRANGE RD
LA GRANGE , IL 60525-4095
(708) 352-7800
Selling Source : 48 - GMC TRUCK
Site Code : 26022
Business Associate Code : 116056
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 01/15/1998 129 miles 01/15/2001 36129 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/15/1998 129 miles 01/15/2004 100129 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/15/1998 129 miles 01/15/2006 80129 miles
36/36000 FEDERAL EMISSION 01/15/1998 129 miles 01/15/2001 36129 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/09/2004 180066 0 J4100 - GENERATOR ASSEMBLY - REPLACE 78637 miles
10/16/2003 176827 0 N3565 - COVER/MODULE, WINDSHIELD WIPER - REPLACE 76836 miles
10/16/2003 176827 0 J5645 - INJECTOR, FUEL - DIAGNOSIS 76836 miles
08/28/2003 174966 0 J3480 - PUMP AND/OR GASKET, COOLANT - REPLACE 75260 miles
04/10/2003 169390 0 R0760 - RADIO, REMOVE AND REPLACE 70847 miles
01/08/2003 165858 0 E9040 - PUMP ASSEMBLY, POWER STEERING - R&R 67616 miles
01/08/2003 165858 0 J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 67616 miles
03/07/2002 152726 0 J0259 - GASKET, INTAKE MANIFOLD (LOWER) - REPLACE 57751 miles
08/21/2001 144250 N H0042 - PADS, DISC BRAKE - FRONT - R&R OR REPLACE 51850 miles
08/21/2001 144250 # T5999 - ADDITIONAL PART MARKUP PERCENTAGE OVER 40% NORM 51850 miles
05/11/2000 121683 # N0480 - LAMP COURTESY (ONE OR ALL) REPLACE. 35114 miles
03/09/2000 118853 B J0990 - PLUG AND/OR GASKET, OIL PAN DRAIN - REPLACE 32489 miles
02/09/2000 117499 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 30664 miles
CHECK HISTORY INFORMATION
Vehicle Has No Associated Check History Information.
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 01/09/2004 Repair Order Number : 180066 Odometer Reading : 78637 miles
Serviced By : DAN WOLF PONTIAC AND GMC TRUCK, INC.
6060 S LA GRANGE RD
LA GRANGE, IL 60525-4095
(708) 352-7800 Selling Source : 48 - GMC TRUCK
Site Code : 26022
Cycle Date Cycle Nbr Case Type Labor Operation Part Auth Code Person Code Line Total Comments
01/16/2004 448 01 0 J4100 - GENERATOR ASSEMBLY - REPLACE 10463652 - GENER REM N/A $ 155.14
Repair Order Date : 10/16/2003 Repair Order Number : 176827 Odometer Reading : 76836 miles
6060 S LA GRANGE RD
Site Code : 26022
10/21/2003 423 01 0 N3565 - COVER/MODULE, WINDSHIELD WIPER - REPLACE 12463090 - MODULE N/A N/A $ 0.00
10/21/2003 423 02 0 J5645 - INJECTOR, FUEL - DIAGNOSIS 12346535 - CLEANER,T N/A N/A $ 33.80
Repair Order Date : 08/28/2003 Repair Order Number : 174966 Odometer Reading : 75260 miles
6060 S LA GRANGE RD
Site Code : 26022
09/02/2003 409 01 0 J3480 - PUMP AND/OR GASKET, COOLANT - REPLACE 12532528 - PUMP KIT N/A N/A $ 110.39
Repair Order Date : 04/10/2003 Repair Order Number : 169390 Odometer Reading : 70847 miles
6060 S LA GRANGE RD
Site Code : 26022
04/29/2003 373 01 0 R0760 - RADIO, REMOVE AND REPLACE N/A N/A N/A $ 0.00
Repair Order Date : 01/08/2003 Repair Order Number : 165858 Odometer Reading : 67616 miles
6060 S LA GRANGE RD
Site Code : 26022
01/14/2003 343 01 0 E9040 - PUMP ASSEMBLY, POWER STEERING - R&R 26069033 - PUMP N/A N/A $ 371.81
01/14/2003 343 02 0 J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 12456152 N/A N/A $ 80.87
Repair Order Date : 03/07/2002 Repair Order Number : 152726 Odometer Reading : 57751 miles
6060 S LA GRANGE RD
Site Code : 26022
03/12/2002 255 01 0 J0259 - GASKET, INTAKE MANIFOLD (LOWER) - REPLACE 12529094 N/A N/A $ 159.55
Repair Order Date : 08/21/2001 Repair Order Number : 144250 Odometer Reading : 51850 miles
6060 S LA GRANGE RD
Site Code : 26022
08/28/2001 199 01 N H0042 - PADS, DISC BRAKE - FRONT - R&R OR REPLACE 18038503 - PAD KIT N/A N/A $ 46.65
08/28/2001 199 02 # T5999 - ADDITIONAL PART MARKUP PERCENTAGE OVER 40% NORM N/A N/A N/A $ 18.33
Repair Order Date : 05/11/2000 Repair Order Number : 121683 Odometer Reading : 35114 miles
6060 S LA GRANGE RD
Site Code : 26022
05/16/2000 65 01 # N0480 - LAMP COURTESY (ONE OR ALL) REPLACE. 09421330 - BULB N/A N/A $ 15.18
Repair Order Date : 03/09/2000 Repair Order Number : 118853 Odometer Reading : 32489 miles
6060 S LA GRANGE RD
Site Code : 26022
03/14/2000 47 01 B J0990 - PLUG AND/OR GASKET, OIL PAN DRAIN - REPLACE 24100042 N/A N/A $ 1.97
Repair Order Date : 02/09/2000 Repair Order Number : 117499 Odometer Reading : 30664 miles
6060 S LA GRANGE RD
Site Code : 26022
02/15/2000 39 01 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 12564763 - BELT N/A N/A $ 38.73
CHECK HISTORY
Vehicle Has No Associated Check History.
Vehicle Build
VIN 1GKFK16R9VJ752947
VEHICLE BUILD
Gross Vehicle Weight Rating : 3314 kg (7307 lb)
Order Number : DQ7287
Build Date : 06/02/1997
Build Plant : 1VJ06
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG9 - 6-WAY POWER SEAT ADJUSTER
AJ1 - DEEP TINTED GLASS
AS3 - FOLDING CENTER & REAR SEAT
AT5 - FOLDING CENTER SEAT
AU0 - REMOTE KEYLESS ENTRY SYSTEM
AU3 - POWER DOOR LOCKS
AXP - VIN IDENTIFICATION
A31 - POWER WINDOWS
A95 - HI-BACK RECLINING BUCKET SEATS
BVE - SIDE RUNNING BOARDS
B33 - REAR COLOR-KEYED FLOOR MATS
B37 - COLOR KEYED FLOOR MATS FRONT AND REAR (CENTER)
B85 - BRIGHT BODY SIDE MOLDINGS
B96 - BRIGHT WHEEL OPENING MOLDINGS
C36 - REAR HEATER
C49 - ELECTRIC REAR WINDOW DEFOGGER
C6A - 7,300 LB GVW RATING
C60 - AIR CONDITIONING-FRONT
C69 - AIR CONDITIONING-FRONT & REAR
DD7 - ELECTROCHROMATIC ISRV MIRROR
DK6 - OVERHEAD CONSOLE
D48 - DUAL ELECT REMOTE CONT MIRRORS
D55 - FLOOR CONSOLE
FE9 - FED/NY/MA EMISSIONS (EXCL. CA)
FK2 - TORSION BAR SPRING ADJ - LH
FK3 - TORSION BAR SPRING ADJ - RH
GU6 - REAR AXLE - 3.42 RATIO
JAN - ASSEMBLY PLANT-JANESVILLE, WI
JB6 - VAC POWER DISC/DRUM BRAKES
KC4 - ENGINE OIL COOLING SYSTEM
KNP - H.D. TRANSMISSION OIL COOLER
K05 - ENGINE BLOCK HEATER
K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER
K68 - ALTERNATOR 105 AMP
L31 - 255HP VORTEC 5700 V8 GAS ENGINE
M30 - 4-SPEED AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL
NA1 - EMISSION SYSTEM - LIGHT DUTY
NF2 - FEDERAL EMISSION SYSTEM
NP1 - ELECTRONIC SHIFT TRANSFER CASE
NP5 - LEATHER WRAPPED STEERING WHL
NRQ - CLOSE COUPLED EXHAUST
NY1 - FUEL TANK SHIELD
NZZ - OFF ROAD - SKID PLATE
N33 - COMFORTILT STEERING WHEEL
PF4 - CAST ALUMINUM WHEELS 16X7
QGB - P245/75R16 ALS SB RAD F/R/S
RSA - PASSIVE AUTO FRT SEAT RESTRAINT
R9L - SLT DECOR
SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS
UP0 - ETR AM/FM STEREO,CD/CASSETTE WITH THEFT LOCK, AUTO TONE CONTROL,SEEK/SCAN, AND CLOCK
UQ3 - ENHANCED PERFORMANCE SPEAKERS
VGC - PAINT ETCH PREVENTATIVE
VK3 - FRONT LICENSE PLATE MOUNT
VP6 - NOISE CONTROL
VR4 - WEIGHT DIST HITCH PLATFORM
VXS - COMPLETE VEHICLE LABEL
V10 - COLD CLIMATE PACKAGE
V22 - DELUXE FRONT APPEARANCE
V54 - ROOF MOUNTED LUGGAGE CARRIER
V73 - STATEMENT OF CERT. U.S.
XGB - P245/75R16 ALL TRN SB RAD WOL-F
YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLE EQUIPMENT / DECOR
YGB - P245/75R16 ALL TRN SB RAD WOL-R
ZGB - P245/75R16 ALL TRN SB RAD WOL-S
ZQ3 - TILT WHEEL AND SPEED CONTROL
ZW9 - STANDARD BODY OR CHASSIS CAB
ZY1 - SOLID COLOR
Z82 - HEAVY DUTY TRAILERING EQUIPMENT
Z88 - GMC TRUCK NAMEPLATE
1SC - MARKETING OPTION PACKAGE - 1SC REQUIRES A MINIMUM PURCHASE OF:
1SZ - MKTG OPTION PKG DISCOUNT
52I - LT NEUTRAL INTERIOR TRIM
522 - NEUTRAL ULTRASOFT LEATHER
6GF - SPRING COMPTR SELECT FRT LH
7GF - SPRING COMPTR SELECT FRT RH
77U - 77 DARK CHERRY MET SOLID
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 01/15/1998
Delivery Type : 010 - RETAIL/INDIVIDUAL
Delivered Odometer : 129 miles
Delivering Dealer :
6060 S LA GRANGE RD
(708) 352-7800
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 26022
Sir, you are a saint. Thank you very much for the information. I just bought this Suburban for my wife and was wondering about the service history and options.
Thanks again,
Rich
