Power Steering
rwthomsonjr
I have an '04 ecsb silverado I bought used with 57,000 miles on it. two weeks after purchase it developed a whine in the power steering, but only when I turn left. No leaks, and I've changed the fluid in the reservior twice. after a fluid change the noise is gone for about a day and then it returns. If I turn the wheel left about a quarter turn and stop the whine begins and fades out. any more left turn pressure and the whine returns but fades out. before I start changing parts does anyone have any ideas as to why???
TommyT
How is the steering assist? Does it have hydroboost? Did you use regular fluid or synthetic?
It does not have hydroboost and I used regular fluid. If it needs synthetic, is it possible to completely flush the enitre system, steering box and pump? Also is there any flow adjustment in the steering box, maybe there is a restriction when turning left. Or could it be a bad left side suspension piece like a bad ball joint?
Based on what you have said, I suspect your power steering gear has an issue in the valving. If you have bad steering components, the drag would be on the entire system, not just when turning left. I believe the steering gear is the only thing that could cause this.
So this means replacing the steering gear? If so would I be better off changing over to the rack and pinion setup. My '01 silverado had this with no problems and 105,000 miles when it was totaled out in a head on.
I would not expect converting your truck to a rack and pinion to be easy or possible. As for the steering gear, depending on where you are, there may be a specialty gear shop around that might be able to fix or rebuild it.
Thanks for your help, I'll ask around for a shop that does this kind of work.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 779 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
