Best Programmer
cdmm151
What is the best programmer out there that will allow the 4 cylinder mode stay engaged longer? will it help with fuel mileage? This is on a 2008 chevy 4x4 cew cab. I also have a 2008 Tahoe that I will do the same, if it helps and will pay for it's self.
You can always get a honda, they STAY in 4 cylinder and you will save all the gas you want. Sorry I tend to stay in 8 cylinder all I can....F the gas prices, I say!!! Milk is $4 WTF
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
