Possesed Truck
bowtieboy03
I have an 05 2500Hd with the Duramax.with 50,000 miles.Last week in the morning when I leave for work ,I have no left speaker ,or key chime,or seat belt chime.I have checked grounds wiggled wires running through door with radio on,and nothing.The weird thing is when I leave work @4pm everything is working.I thought maybe i was getting moisture somewhere,but last week when it rained everyday it still fixed it self.This is driving me crazy!!!I talked to friends with garages,and even called dealer where I bought it.Dealer says bring it in we'll look at it,but @ $90 per hour to find nothing is a big gamble.When it is working,I have even taken it to rough roads thinking loose wire and still can't get it to stop working!!!Any suggestions would be greatly appreciated.
Have you checked all the fuses? Even if the problem is only intermittent, you might find something in either the underhood fuse box or dash panel.
Done that.
Sister has a 78 GMC, everyonce in a while the wipers will work one time by them selves? It may happen once a day for a week and then not happen again for more than a month!!! It has done this since new!! And it will still do it today(or maybe the next or maybe not)!! I would tell you lots of luck. :)
door chimes are routed thru the radio. the problem could be internal to the radio. lots of issues with the factory radio head units.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
