2000 Tahoe Downshift Clunk
Hello,
I have 138,000 on my 2000 Tahoe and I'm getting a rather noticeable and irritating clunk when slowing to a stop. It happens when the transmission shifts from 2nd to 1st I believe. It is happens all the time unless I have the truck in 4 wheel drive. Unfortunately my GM mechanic buddy miss-diagnosed the problem as a worn Spider Gear Set and after a $500 repair its still doing the exact same thing. There is also a loud clunk when shifting into Reverse from Park or Nuetral. (No noise when shifting into Drive)
Advice much appreciated.
After digging a little deeper I found information that suggests my problem might be the slip yoke? Some say they grease this and the clunk goes away. Any thoughts on that?
Again, much appreciated
Can't hurt, and could be, if the slip joint is hanging up any suspension travel (like coming to a stop etc) would cause a clunk/judder noise, but going into 4wd wouldn't make it go away...
Do you notice it at any other time at any other speeds? If you do, I would say it might be u-joints. If not, I am surprised your friend said spider gears, because with worn spider gears it would also happen all the time, not just on downshifts.
If not u-joints I would think it points to something internal in the transmission. Have you gone through the tech wiki for TSBs?
I have not used the tech wiki, new to this site so will check that out. I did find out information that if it was the slip yoke it would only do it when coming to a stop and taking off from a stop and not while shifting. So, it appears thats not it. It does not do the "clunk" at any other time, only when slowing down and the truck downsifts from 2 to 1. A neighbor who is a diesel mechanic listened to it today and is pretty sure it is in the tranny. (not the best news I guess) I'm not sure what to try next, perhaps take it somewhere and hope for the best. Thank you for your help.
Walleye Mark, do you have a rivalry with Walleye Dan? :dunno:
Luckily there are enough walleyes for all of us! I wouldn't mind trading some tips with Walleye Dan though. I'm just worried about getting my boat to the lake ramp with this dreaded clunk.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,262 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
