Complete Intake Sytem Service
Guy at the local auto repair shop has this big fancy mac-vac or something system. Looks like some kind of large wheeled battery charger. It comes with a fancy flyer that list all the benifits of this service. Things like , power, MPG, and the like. Says it hooks up to your intake some how and sends consentraited cleaner through the throttle body and all the injectors and everything else.Says it cost about $120 and should be done every 15,000. What do you tech savey guys think out there. Anyone ever have this ? ANyproblems after the fact ? Open for suggestions
thanks
Scott
Just do a seafoam treatment through the intake and that would cost you what, six bucks for the can? Then an additional 6 quarts of oil for a change after wards. A lot cheaper than a 120 bucks.
This has been a fairly popular "add on" service for many quick lubes and Dealerships. I am not convinced it is a total waste of money for someone who has not mechanical skills at all and is not willing to do this at home.
There are a couple of options with the cheapest and more simple being SeaFoam Deep Creep injested through the TB. However, this requires you to get the DC into the system while the air is still flowing through the MAF sensor. Seafoam also now makes a 24" multi hole straw so you can reach the back intake ports while the motor is not running.
MMM has just introduced a new DIY kit, part # 08963 that includes a can of TB cleaner, a bottle of their premium fuel system cleaner that is added to the tank (same product as Techron I am told) and a new intake cleaner that is injested through the TB through a "S straw" while the motor is running. The "S straw" is simply inserted into the TB under the rubber boot and the boot is put back in place. The can has a locking trigger and you crank it up, lock the trigger and let it spray into the intake. This product is very new and I am not even sure we have it in stock yet.
Here is a link to MMMs website and a 6 min video demonstrating the kit. MMM Intake Kit 08963
If I decide to perform this service on my Yuk XL , this is what I will likely do.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 484 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
