Whats It Called ? Vin Check ?
Hi all, new denali owner here.
Can someone tell me what this is called, and were can i order one ? The fiberglass panel running along the bottom ? I need it for the passenger front door and the little piece that is on the fender. I got a good deal on a used denali and its missing that piece on the door.
Can someone do that vin check for me that i have seen on here, that lists the options in my car.
1GKFK66U23J179937
Thanks
1GKFK66U23J179937
Thanks
Nope, how about beer check?
GM Vehicle Inquiry System
Summary
Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
Help
VIN : 1GKFK66U23J179937
VEHICLE INFORMATION
Merchandising Model : TK15906 -2003 YUKON XL DENALI - AWD Warranty Start Date : 12/20/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : BUDDY STASNEY S BUICK PONTIAC GMC TRUCK,INC.
PO BOX 833
LINCOLNTON , NC 28093-0833
(704) 735-3051
Selling Source : 48 - GMC TRUCK
Site Code : 08201
Business Associate Code : 165235
Service Contract :
No
Branded Title :
No
Warranty Block :
No
PDI Status :
Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Type
Number
Description
Posted Date
Status
SB
06047
ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. ??
02/21/2007
See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID XCLB10R2 XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description
Effective Date
Effective Odometer
End Date
End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY
12/20/2002
245 miles
12/20/2005
36245 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY
12/20/2002
245 miles
12/20/2008
100245 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM
12/20/2002
245 miles
12/20/2010
80245 miles
36/36000 FEDERAL EMISSION
12/20/2002
245 miles
12/20/2005
36245 miles
CLAIM HISTORY
R.O Date
R.O Number
Type
Labor Operation
Odometer Reading
10/23/2003
166021
J0900 - CAP, OIL FILLER - REPLACE 28593 miles
10/23/2003
166021
R9225 - AIR CONDITIONING 28593 miles
10/23/2003
166021
Z7902 - 2-DAY COURTESY TRANSPORTATION 28593 miles
10/16/2003
165830
N8520 - MODULE AND/OR SWITCH, DOOR -- REPROGRAM WITH SPS 27957 miles
11/21/2002
A79937
I
Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
? 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
Help
CLAIM HISTORY
Repair Order Date : 10/23/2003 Repair Order Number : 166021 Odometer Reading : 28593 miles
Serviced By : BUDDY STASNEY S BUICK PONTIAC GMC TRUCK,INC.
PO BOX 833
LINCOLNTON, NC 28093-0833
(704) 735-3051 Selling Source : 48 - GMC TRUCK
Site Code : 08201
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
10/28/2003 425 01 # J0900 - CAP, OIL FILLER - REPLACE 24100002 - SEAL N
10/28/2003 425 02 # R9225 - AIR CONDITIONING N/A N
10/28/2003 425 03 # Z7902 - 2-DAY COURTESY TRANSPORTATION N/A N
Repair Order Date : 10/16/2003 Repair Order Number : 165830 Odometer Reading : 27957 miles
PO BOX 833
Site Code : 08201
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
10/21/2003 423 01 # N8520 - MODULE AND/OR SWITCH, DOOR -- REPROGRAM WITH SPS N/A N
Repair Order Date : 11/21/2002 Repair Order Number : A79937 Odometer Reading : 0 miles
Serviced By : LOU SOBH BUICK PONTIAC GMC OLDS
PO BOX 1047
LITHIA SPRINGS, GA 30122-7047
(770) 941-0099 Selling Source : 48 - GMC TRUCK
Site Code : 53371
Business Associate Code : 167240
Cycle Date
Cycle Nbr
Case
Type
Labor Operation
Part
Comments
11/26/2002 329 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
Help
VIN 1GKFK66U23J179937
VEHICLE BUILD
Gross Vehicle Weight Rating : 3269 kg (7208 lb) Order Number : FTFZSD
Build Date : 11/21/2002 Build Plant : 13J06
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - POWER DRIVER SEAT ADJUSTER AG2 - POWER FRONT SEAT ADJUSTERS
AJ1 - DEEP TINTED GLASS AJ7 - DRIVER/PASS FRT & SIDE AIR BAGS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT AL4 - SECOND ROW CAPTAIN'S CHAIRS
AN3 - FRONT FULL-FEATURE RECLINING BUCKET SEATS AP9 - CONVENIENCE NET
AS3 - THIRD ROW 50/50 SPLIT BENCH SEAT AU0 - REMOTE KEYLESS ENTRY SYSTEM
AXP - MPV VIN IDENTIFICATION A31 - POWER WINDOWS
BS1 - INSULATION ACOUSTICAL PKG BVF - RUNNINGBOARD, COLOR KEYED
BW2 - DELUXE BODY SIDE MOLDINGS B30 - COLORED - KEYED CARPETING
B39 - CARPETED LOAD FLOOR B58 - FRT & CTR CARPETED FLOOR MATS
CF5 - POWER SUNROOF HOMELINK CJ2 - TRI ZONE AUTOMATIC AIR CONDITIONING
C25 - REAR WINDOW WASHER/WIPER C36 - REAR HEATER
C49 - ELECTRIC REAR WINDOW DEFOGGER C5Z - GVW RATING - 7,200 LBS
C69 - REAR AIR CONDITIONING DF5 - LT SENSITIVE INT R/V MIRROR W/OUTSIDE TEMP & COMPASS
DH2 - ILLUM LH & RH VISOR MIRRORS DK8 - DELUXE OVERHEAD CONSOLE
DL3 - EXTERIOR MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL &GROUND ILLUMINATION D07 - FLOOR SHIFT CONSOLE
EVA - EVAP EMISSION REQUIREMENT E52 - LIFTGATE W/LIFTGLASS
FE9 - FEDERAL/NY/VT EMISSIONS FK2 - TORSION BAR SPRING ADJ - LH
FK3 - TORSION BAR SPRING ADJ - RH GT4 - REAR AXLE - 3.73 RATIO
G69 - LEVEL CONTROL AUTO, AIR, HD JAN - ASSEMBLY PLANT-JANESVILLE, WI
JF4 - POWER ADJUSTABLE PEDALS JH2 - BRAKE HYD POWER, DISC
JL4 - STABILITRAK KA6 - REAR HEATER SEAT
KC4 - ENGINE OIL COOLING SYSTEM KG3 - ALTERNATOR 145 AMP
KNP - H.D. TRANSMISSION OIL COOLER KUP - THROTTLE CONTROL ELECTRONIC
K34 - ELECTRONIC SPEED CONTROL K47 - HIGH CAPACITY AIR CLEANER
LQ4 - VORTEC 6000 V8 SFI GAS ENGINE M32 - 4 SPD AUTO TRANS, ELECTRONIC
NA1 - EMISSION SYSTEM - LIGHT DUTY NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHL NR3 - AUTOMATIC TRANSFER CASE
N93 - POLISHED CAST ALUMINUM WHEELS PDC - CARGO PACKAGE
PDQ - SECURITY PACKAGE QAN - P265/70R17 ALS BW TIRES
RYJ - RETRACTABLE CARGO AREA COVER R4Y - TIRE BRAND ALL GOODYEAR
R6J - CUSTOMER DIALOGUE NETWORK R9Z - POMS EXPEDITE-SOLD ORDERS
SAF - SPARE TIRE LOCK SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS TL1 - DELUXE GRILLE W/COMP. HEADLAMPS
T74 - HEADLAMPS CONTROL AUTO, DELAY T96 - FRONT FOG LAMPS
UB1 - AM/FM STEREO W/CD, CASSETTE AND BOSE SPEAKER SYSTEM UE1 - ONSTAR COMMUNICATION SYSTEM INCL 1 YR SAFE & SOUND PLAN
UG1 - UNIVERSAL GARAGE DOOR OPENER UK3 - STEERING WHEEL RADIO CONTROLS
UK6 - REAR SEAT AUDIO CONTROLS UQ7 - BOSE SPEAKER SYSTEM
U1S - 6-DISC CD CHANGER U2K - XM SATELLITE RADIO-100 CHANNELS OF COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA)
VR4 - WEIGHT DIST HITCH PLATFORM VT4 - BUMPER FRT COLOR KEYED
VT5 - BUMPER RR COLOR KEYED VXS - COMPLETE VEHICLE LABEL
VZ2 - SPEEDOMETER CALIBRATION V1K - LUGGAGE CARRIER CROSS RAILS
V54 - ROOF MOUNTED LUGGAGE CARRIER V73 - STATEMENT OF CERT. U.S.
V76 - RECOVERY HOOKS XAN - P265-70R17 - 113S BW FRONT
YAN - P265-70R17 - 113S BW REAR YD3 - BASE EQUIP FOR SCH GVW PLATE
YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR
Y91 - DENALI PACKAGE ZGC - P265/75R16 BW SPARE TIRE
ZY1 - SOLID PAINT Z55 - AUTORIDE
Z82 - HEAVY DUTY TRAILERING EQUIP. Z88 - GMC TRUCK NAMEPLATE
1SF - DENALI MARKETING OPTION PKG-1SF 1SZ - OFF-ROAD PKG DISCOUNT
41U - ONYX BLACK 52I - NEUTRAL INTERIOR TRIM
522 - NEUTRAL INTERIOR TRIM 6XL - COMP FRT LH COMPUTER SEL SUSP
7XL - COMPONENT FRT RH COMP. SEL SUSP
Vehicle Component
Help
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : W - CPC/DDA ROMULUS, MICHIGAN
Part/Num Broadcast : FUH Traceability : 023121481
Date Scanned : 11/21/2002 Time Scanned : 08.00.00 Scan Station : 01
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : XTN Traceability : 761443112
Date Scanned : 11/21/2002 Time Scanned : 07.28.00 Scan Station : 01
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : C
Part/Num Broadcast : WR Traceability : 043039
Date Scanned : 11/21/2002 Time Scanned : 08.30.00 Scan Station : 01
Component Code : 61 - TRANSMISSION
Source Plant : R - HYDRAMATIC THREE RIVERS, MICHIGAN
Part/Num Broadcast : 3KZD Traceability : 34978026
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : TUF Traceability : N100260
Date Scanned : 11/21/2002 Time Scanned : 08.18.00 Scan Station : 01
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : PW5 Traceability : 032037
Date Scanned : 11/21/2002 Time Scanned : 08.41.00 Scan Station : 01
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YCTJ Traceability : 22318KGYA
Date Scanned : 11/21/2002 Time Scanned : 11.56.00 Scan Station : 01
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 4170 Traceability : 32318D543
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 3546 Traceability : 00040990
Date Scanned : 11/21/2002 Time Scanned : 09.16.00 Scan Station : 01
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 5377 Traceability : 9CFR01X
Date Scanned : 11/21/2002 Time Scanned : 08.25.00 Scan Station : 01
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : V - DELCO ELECTRONICS REYNOSA MEXICO
Part/Num Broadcast : 7506 Traceability : 2311HEVAX
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 7506 Traceability : 2311HEVBJ
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 2350 Traceability : 8WCKZ70
Date Scanned : 11/21/2002 Time Scanned : 07.19.00 Scan Station : 01
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 2444 Traceability : 123182RGY
Component Code : AT - RIGHT SIDE IMPACT SENSING MODULE
Part/Num Broadcast : 7508 Traceability : 231402BH2
Component Code : AU - LEFT SIDE IMPACT SENSING MODULE
Part/Num Broadcast : 7508 Traceability : 2313028W1
Component Code : BO
Source Plant : X
Part/Num Broadcast : 1372 Traceability : 0231705C6
Component Code : BP
Source Plant : X
Part/Num Broadcast : 6208 Traceability : 023170C01
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 0820281
Date Scanned : 11/18/2002 Time Scanned : 09.27.00 Scan Station : N/A
Component Code : CF - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1WW Traceability : 0659835
Date Scanned : 11/18/2002 Time Scanned : 20.46.00 Scan Station : N/A
Component Code : CG - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1PP Traceability : 0658217
Date Scanned : 11/20/2002 Time Scanned : 15.06.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1GG Traceability : 0655685
Date Scanned : 11/21/2002 Time Scanned : 01.33.00 Scan Station : N/A
Component Code : ZU
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : XCLB10R2
Component Code : ZV
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : 223120227
Component Code : ZW
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : 842215730
Component Code : ZX
Source Plant : 6
Part/Num Broadcast : 0009 Traceability : 77695
Component Code : ZY
Source Plant : 4
Part/Num Broadcast : 1190 Traceability : 305330
Help
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 12/20/2002 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 245 miles
PO BOX 833
(704) 735-3051
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 08201
Dealer Information
Help
INVOICE INFORMATION
Invoice Date : 11/21/2002
Site Address : LOU SOBH BUICK PONTIAC GMC OLDS
PO BOX 1047
LITHIA SPRINGS , GA 30122-7047
Site Code : 53371
SHIP-TO INFORMATION
Ship-To Date : N/A
PO BOX 1047
Site Code : 53371
are you talking about the door molding??? A closer/better pic might help. It also looks like you are in the general area for the emblem
You talking about this? (Click to open in a new window for the animation)
If so, then that would be the door molding, MS3Dale should be able to pull the part number for you.....
Thanks ! Yea thats it, i need the panel on the Psgr Door and the small one that is on the fender.
Send MS3DALE a PM with your VIN and he should be able to pull the part numbers for you
The front passenger door molding is part#19120552
The front passenger fender molding is part#88980822
Thanks rich
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   1 Member, 0 Anonymous, 669 Guests (See full list)
