Another Torsion Bar Question?
I know this has been beat to death but I searched and haven't found exactly the answer I need. So on my newly aquired '05 Silverado 4x4 w/Quadrasteer, I wanted to raise the front some as the non Z71's seem to rake towards the front alot.
I did a preliminary measurement from the ground to the wheel well with the tires inflated the same. I came up with 36" from ground to fender lip. I then proceeded to jack the truck up and turn the bolts 4 complete revolutions. These are the measurements I cam up with afterwards. Passenger side ground to fender lip = 36 7/8", Passenger torsion bolt thread still showing = 1/4". Drivers side ground to fender lip = 37 1/8", Drivers side torsion bolt thread still showing = 3/8".
So my questions is this: What is the goal of cranking up the torsion bars besides raising the front of the truck? Should these measurements be equal on both sides of the truck from the ground to the fender lip, is this what the torsion bars level out? Is it acceptable to have this much difference between thread showing?
What is the ultimate goal of the measurements?
Sorry for all the questions, I just want it to be done right.
Thanks, Erik
Thanks, Erik
The only real goal of cranking is to 'lift' the front of the truck, and level it side to side. The difference in thread showing is perfectly normal. If I were in your situation, I would crank the drivers side so the truck will be sitting level side to side. Also, before you take your measurements, bounce on the bumper, and drive around the block to let the suspension settle a little bit.
Also, make sure you get an alignment when you're at the desired height.
My drivers side is already higher then the passenger side so cranking it would actually raise it even higher. i assume you meant crank the passenger side to level it out or lower the driver side to level it out?
Thanks for the fast reply.
Erik
Erik
Yeah sorry I read the measurements wrong. You don't want to crank much more than an inch over stock height, or your ride will start to suffer.
So I have about 1/4" of thread showing between the head of the torsion bar bolt and the metal bracket is this as far as they can be adjusted. There seems to be alot of threads showing on the bolt between the bracket and the key. As I turn the bolt in does the key go up or does it thread down on the bolt?
Thanks, Erik
The key goes up.
So once the head bolt is bottomed out on the bracket that is it correct?
Yup. I just cranked mine up, and when the passenger side bottomed out, there were still about 1/4" left on the drivers side bolt.
    btm
    btm
  • Who's Online   5 Members, 0 Anonymous, 1,504 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
