Wtb Aluminum Intake
I am looking to buy an aluminum intake for a 2001 Silverado 2500hd with the 6.0. Am converting to propane and cant use the facory plastic one
why?
intake for ls2 block
Well here are your issues.
The only one that I really know of is the Weiand aluminum LS intake.
1. the TB size is 80mm (78mm) and not 90mm.
2. You would need to modify the valley cover on the LS2 to make it fit. Will it fit? Yes, I bolted one to an LS7 (with LS2 heads)
Look up the intake online and let me know.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
