Engine Miss
Anyone else with a vmax notice what appears to be a miss while slowly accelerating at cruising speeds? It seems to happen between 1500 and 2000 rpms while cruising in OD. Also seems to be worse when running the AC.
Yep, I have it also. It's real bad when under a load. Pulling a trailer it's really bad.
The engine really surges at that RPM.
I would be curious if there was a service bull. on it. (I know, you can't share it with me, but maybe there is a "re-flash" for It out there)
Mine does that once in a while pretty badly, but it's not a vmax engine. Mine is probably due to an intake gasket leak.
  • 1 month later...
Anybody else have any info. on this issue? GM techs, engineers, parts people, tuners. :D It is the only real gripe I have about my truck right now :lol: . One of the mechanics at the dealership I bought at has a vmax with the same issue and he hasn't figured it out yet either.
Mine too, but change to 93 OCT and see what happens. Mine cleared up, so after a while couple of tanks i went back to 87 and it came back. That is my best guess on it currently.
i thought all 6.0 engines only ran high test fuel?
I've run nothing but 87 octane in mine since I got it in June. I had Justin do my tune based on using 87. I know I would get a lot better performance from 91 or 93 but my VMAX runs ok on 87 (for now).
  • 9 months later...
Anyone else with a vmax notice what appears to be a miss while slowly accelerating at cruising speeds or trying to maintain speed on a slight grade? It seems to happen between 1500 and 2000 rpms while cruising in OD. Also seems to be worse when running the AC.
Just thought I would bring this up again and see if anyone has anything to add from almost a year ago. My truck still has the same problem :) and I have not found a cure.
I don't have the VMAX, but my 6.0 starts misfiring and flashing CEL's while on the highway at about 65 mph and a constant 2600 rpm's. The mechanic from the dealership said it was plugs n wires.
Well I'm glad nobody else has this problem, but It sucks that I'm the one that does have it. Tried the dealership once already for a fix, guess I'll try again.
Stay on them... I would keep bringing it back till your satisfied. I makes me mad when dealers use the phrase "Normal condition" or "Cant reproduce the issue" Just means they didn't look close enough. Not all dealerships do that, but anyone that's had service done has heard one of those phrases. I'm just glad I don't have all these little issues with mine.
Only issue I've had in 30,000 miles was the rear-main seal and trans seal. But I heard that was pretty typical of the GMT-900's so I'm not worried about it.
I still have it also. I haven't been to the dealer for anything yet. Although, I should take it in for the heated washer fluid stupid thingy.
Just thought I would bring this up again and see if anyone has anything to add from almost a year ago. My truck still has the same problem :confused: and I have not found a cure.
I have yet to go back to the dealer for any service either. That's a good thing. I may have to give in though just to get this looked at. I know one of the mechanics there and he has the same truck with same issue and has not figured anything out yet.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
