I was looking for others opinions on my brush guard, I am looking to see if I should get rid of it or keep it ? I mean I like it but its a PITA to clean under and around the bar when washing my truck and its kinda overkill and is gonna be expensive to replace with a chrome one as I am doing that with my side bars. Thanks for your help.
This is what it looked like when I first bought it but since did alot of modifications to it.
This is what it looks like today
Are you going to be driving your truck anywhere that would require guarding the front from brush?
if not, ditch it.
I say take it off, you can always put it back on if you don't like it off. Are you keeping the moon-visor?
Well if I take it off im gonna sell it because im moving and will have my jet ski and truck in the new garage and won't have room for the brush guard to sit around and collect dust and the moon visor I will end up keeping because if I remove it then ill have the holes on the roof to deal with.
    Gkistler
    Gkistler
  • Who's Online   6 Members, 0 Anonymous, 921 Guests (See full list)
