Wont Turn Over
I HAVE A 99 SUBURBAN STARTED FINE THIS MORNING WENT OUT 30MINS LATER TO LEAVE FOR WORK AND IT WONT EVEN TURN OVER. I TESTED THE STARTER ITS GOOD ALL MY ACCS WORK FINE BUT THE TRUCK WONT EVEN ATTEMPT TO TURN OVER. BATTERY HAS TESTED GOOD AND ALL THE WIRES LOOK GOOD. ANYONE HAVE ANY SUGGESTIONS
Does the solenoid click?
Friendly Info: I'd recommend not using all caps either, some people take that as screaming and get all bent out of shape over it.
Fuel pump? bad starter? Too much screaming? :lol:
Sorry about the caps i have replaced the terminals and the starter has been tested but while in the car there is nothing not even an attempt to engage from the starter. I do hear a click under the dash like a relay swithing
New or old style 99? Engine?
5.7 vortec
Let's see what we've established here so far....
- starter motor bench checked good
- battery cable terminals replaced
- solenoid is NOT clicking
- starter relay IS clicking (which tells me it's probably not the ignition switch)
Have you checked your ignition fuses? If they're good take out the relay and test the battery positive voltage circuit to see if you have 12 volts there.
All fuses are good not sure how to check the positive voltage circuit
First of all you'll have to find the relay and I have no clue where it is on your vehicle but you might try following the clicking sounds. Remove it from the wiring, relay panel or wherever it's plugged in and test the receptacle w/ a test light for voltage. One leg should be hot, no voltage on the others. Test it w/ the ignition switch OFF.
I think we're getting too complicated here. Unless I missed something we don't know if there is power at the starter yet. Get a test light connect one side to ground and the other side to the big terminal at the starter. You should have power there all the time. Take the test lamp with one side still connected to battery ground and have someone crank the truck with the other end of the light on the small wire at the starter. It should light with the key in the crank position. Let us know what you get.
Ok so you had light on the test lamp when you should have. Get a breaker bar and the right size socket, put it on the crank pulley bolt and turn the motor by hand. It's not likely you have a siezed motor but it's easy enough to check how I just said. If the motor turns by hand and not by starter and you have good battery power at the starter and good switched power at the starter then you need a starter.
There is another option which is battery cables but you would need to be pretty handy with a good voltmeter to check those. If the enging turns by hand put a starter in it.
the guy I baught the truck from told me to try a screw driver to both positive terminals on the starter so i did and it started and has started about ten time with no problem since i guess i might need to replace the cable going to the selinoid
    FiLo
    FiLo
  • Who's Online   5 Members, 0 Anonymous, 627 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
