Diffrent Look Maybe?
ok as you know i got hit well had the bumper trim ripped off and broken had replacment bumper added .
but the molding isent in stock were i ordered it from also i fear the new molding would stand out badly agenst the old stuff on sides .
so should i fill the mounting holes in bumper and go smooth look and remove the trim totaly on the sides ?
or should i buy new trim for the sides ?
also i have new lower sport package air damn on way that one on truck is temp for moment as that was broken also .
but should i paint new lower air damn red also when i get it ?
and yes i know bumper looks orange its not
I'd smooth it out, personally.
On a side note, you need a different camera so we can see what's going on. Unless you happen to live in a very foggy area, I think there's something wrong with yours!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
