Fan Blower, Not Working ?
Whats up everybody.
This is my first topic. Here we go.
2005 Sierra V-6 1500
I just bought it in April, cash.
It was used, I wasnt ready to go to the dealer and hand over my wallet.
So I got it from a local for sale by owner.
All was good for awhile then suddenly the fan blower stopped working, i researched and discovered that when I jiggle or inspect the resistor and the wire connector on the fan blower motor, the fan blower tends to work after that. I also noticed that after I run the A/C for about 5 min. and shut off the truck. The Connector & plug are Burning HOT.
This is obviously a problem. What is the solution? Mytheory is- this will only work temporarily until the wires melt and the connector or plug or Both are completely useless.
Is there a factory product capable of correcting this?
I need some good pointers, I'm talking guys with GMC Tattoos. Any and all welcome.
Thanks in advance. :dunno:
Welcome to the site Mario, this is pretty common but I don't know if there is a pigtail to install. If you disconnect the resistor and take a close look at the face of the connector you will see that one or more of the terminals has gotten hot. If you look really close you can see that the terminal has lost it's tension. I usually pull all of the terminals and replace them but there are no part numbers for the terminals and they take special tools to replace. The best guy I know to tell you if there is a replacement pigtail is MS3DALE if he comes in here. If not I can get you the terminal numbers but they are not available (usually) through parts, you would need to get a technicain to hook you up with them usually. I usually just replace the resistor at the same time because it's burnt and it will come back sooner or later. If it was mine I'd probably wait but then again I have an endless supply of terminals if I burn another one. If I were you I'd replace the resistor at the same time that you repair the connector.
So in laymans terms, if I replace the male and female connectors, I'll be ok?
Is this type of fix temporary?
I live in Mesa, Arizona and I'm outside all day at my work & it's 105 degree weather. My last truck had A/C issues because it was Nissan 4 banger, it couldnt keep up with the heat. I just want to have something that works, this type of weather stresses me out after a long day and it don't cool off until Oct. 4-5. I havent heard anything from ms3dale, i dont know how to ask him for advice.
This reminds me of my old xbox 360, I hope I dont have to get of this because of overheating issues. If you know other threads I can look into, it would help out alot, because the search engine in this site is not showing me anything. thanks in advance.
Check www.rockauto.com for the pigtail and the resistor. They have it all listed for your truck.
Cool, thanks for pointing me in the right direction bossier62guy.
I checked it out, its a little hard to navigate but it will take a little time to figure out the cost.
Hopefully, everything will work out.
You might still contact "MS3Dale" via PM and make sure you get the correct part numbers....you can probably get a better deal thru www.gmpartsdirect.com than from rockauto on those specific items.
    FiLo
    FiLo
  • Who's Online   5 Members, 0 Anonymous, 627 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
