Freaking Epson!
SnakeEyeSS
:dunno::lol::lol::thumbs::D
This is unbelievable. Last time I booted up my printer, 3 of the 4 inks were at around 10%. I printed in black ink only. this time I booted it up it says the same thing. I try to print, and all of as sudeen, the black cartridge is empty....ok, I replace it. Try to print.....a SECOND cartridge is empty, this one read over 10%....strange, down to zero, also, with no use but I replace it.....try to print...........THE THIRD cartridge is empty, once again, without being used. They have read 10% the last 3 or 4 times I printed something in black ink only.. I only use color for photos, and haven't printed in color in quite some time.
Blatantly ripping off the customer is not a good way to get repeat business.
