Gm Factory Nav
I recently installed a factory nav unit on my 07 sierra, the gps tells me I am in washington dc, but I live in tucson az. can anybody tell me what is going on. i tried a different nav disc, but that isn't it. any suggestions would be helpful thanks.
Have you tried going pressing the destination button and the select the large button (on the touch screen) that says Change search area? Then on the map that it gives you select your state. If that doesn't work. I don't know. Good luck
I know that if a GPS unit has been turned off for quite awhile or moved a large distance from when it was last turned on and receiving signals, it may take a long time for the GPS to acquire the signal and recalibrate it's location.
Does the display show that you're getting a signal? How long have you driven around with the NAV system on? What I discovered about the GM nav system is that if it is off, it turns the antenna off and doesn't do any tracking at all. I'll get a No GPS display for a few minutes if I've driven around with the GPS off.
When I was test driving my Yukon, it had been brought up from downtown. When we turned on the GPS, it still showed as if the vehicle was downtown--even though we weren't. The salesguy took out the Nav disc and reinserted to reset the system and then it showed us the proper location.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
