Taking On Water
It rained out last night, I noticed some water on the passenger floor. After some investigation, I followed it up and it looks like it is starting in the area where the triangular panel alongside the dash snaps out. Not a lot of water but droplets and some little streaks all the way down the plastic inside molding, till is lands in the rubber door molding. I hope that is a clear enough description It is a 2005 Sierra ext. cab. Anyone have any suggestions? Thanks in advance, Jake.
check the drain tubes that run from the cowl to under the truck, if you park under trees they could be cloged causing the water to run into the truck
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,290 Guests (See full list)
