8.1l oil loss
i have a problem has anyone check their oil between oil changes?(3500) well anyway i talked to the dealership and they told me that its normal. for the first change anyway im at almost 6k miles i filled up my truck and the damn oil wasnt even on the stick!! i was worried OMG whats going on??? last week when i turned 5k i had the spiin on filter on the alli changed and the oil checked everything fine went 700 miles this weeken returned to ft worth and check the oil at fill up no reading!!! some one help me..!!! truck runs awsome getting 12 mpg city!! just worried. maybe i should have gotten a dmax :D
It seems with these trucks the best time to check the oil is if they have been shut off for at least 1/2 hour or more.  Since they have an anti-drainback filter (on most models) the oil stays in the gallies for awhile.
I check my 6.0L with the motor cold.  I was at the second hole from the top of the stick when my change oil light came on.  So I used only a few ounces in between changes.
BigBlocks tend to use a little more oil, and a quart in between changes shouldn't surprise you, especially if you are working the truck hard.
I don't know if the 8100 has the anti-drain back filters, but I bet it does...
FYI, you're not going to like this answer but Big Block V8's since their inception way back yonder EAT OIL!!!  Period!  No if's ands or buts aboot it.  Ford and Chrysler Big Blocks were even worse than their GM counterparts.
With that said, my truck now has 4,200 miles on it.  I've already changed the oil three times.  Between the 2nd and third time when I actually physically checked it, I too was about 1.5 quarts low.  One must also factor in that up until about 6k, these new engines are still technically "breaking in" or more correctly "loosening up."  As such, expect oil usage to be a little higher than normal.  Somewhere between 6 and 10k miles you should see this break in usage taper off and then it's just regular big block oil swilling problems.
While yours does seem extensive, it is perfectly normal (as much as I hate to say it and you hate to hear it) for an engine of this size and of this large reciprocating mass.  I would make it a point to your service department that this thing is EMPTY and not just low and there could be something more critical at hand.  I just want you to realize that these things DO eat oil.
I've always heard from the old timers that a healthy motor will use some oil, not to leave clouds and puddles on the driveway, but I  know of the motors I've had, my 350 in my old 85 chevy used 1-2 quarts in 2000 miles. It never smoked and it was hopped up for pulling my trailers. If it doesn't smoke or rap, oil is cheap, and like the guy said in the previous post, big blocks like oil and a lot of it.
thanks guys its my first gm i have always bought ford or dodge diesels and i made the switch because this is a awsome truck. i just dont want to break it i haul alot of live stock im either pulling my 40 or 45 foot stock trailer alot and just worried about that. im going to put the larger oil filter and i guess go to using rotela or doesn anyone have a suggestion on a good conventional oil .. thanks for all your help.. :D
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
