Synthetic Oil
ArmyAviator
2000 GMC Sierra 5.3 4x4 with 190K; solid truck; no oil burn; no leaks; tediously maintained. About 50K ago, tech talks me into full synthetic Mobil 1. I have synthetic in 1-ton diesel and 07 Tahoe, so I go for it.
All is well....I think....but of late, at 5-7K, I change oil and it's "muddy". Like dark milk chocolate, and there are a few "lumps" at the bottom of stream....sorta gelatin-like. it's not true milky like water in it, though there is a small amount of condensation under oil cap; tech says that's normal. ?? Could the Mobil 1 be cleaning up a lotta crap in there? Truck is rarely off road.
Oil pressure is 38-40 @ idle, maybe 42-44 @ cruise. I do notice that just last week, at start, the oil pressure comes up then drops really low for a blink and comes right back up with no further repeat.
No overheating; coolant is okay but it's always "used" about a pint every 3K.
Thoughts?
Thank you.
--Bryant
Those are all symptoms of coolant leaking into the oil.
+1
Synthetic oil never comes out muddy unless it is contaminated. Mine comes out looking better like new dino oil after 5K. Couple that with the fact that no truck "uses" coolant normally. You have a small leak internally somewhere. Can't be doing your main and rod bearings any good.
  • 4 weeks later...
Thoughts?
Thank you.
--Bryant
Thoughts?
Thank you.
--Bryant
I have a 2001 5.3 Silverado. I had a oil analysis done by blackstone labs and ran Q synthetic for around 6k, which normally I wouldnt do, but I was reading all this stuff that synthetic could run longer than conventional. Blackstone said that I had abnormally high amounts of lead, of course from bearings. i also had Iron, and another type of metal present, I think that he said aluminum from the pistons. I do have piston slap. The tech that I had spoken to told me that for some reason these trucks bearings seem to have problems when switching to synthetic, he told me that he would use regular castrol and change it every 3k. I also had sodium which he said that Q uses in their oil and that they would do a free analysis to see if it is the oil, he said that if that is not the case then it would be from antifreeze, which it doesent seem that I am losing antifreeze.
If your antifreeze is going down at all I would find the cause of this right away. The tech told me that it is probably an intake gasket which I have read that these trucks have a problem with. You probably should maybe see about getting a pressure test done. I know that I will be watching mine close now so I dont dilute my oil.
Thoughts?
Thank you.
--Bryant
I would never believe that the bearings would be hurt by switching to synthetics. The tech blameing the oil, is either mistaken, or just doesn't like synthetic oil. Mark.
I agree 10000000000%
Synthetic oil will not harm anything. It's quite the opposite actually. The only way the lubricant caused that is if it was contaminated by something.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,196 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
