Volume Wide Open In 07 Tahoe Nav/radio
I have picked up a vandalized 2007 Tahoe LT3 4WD 5.3 liter that originally came with CD/DVD/MP3 radio (UVA) and Bose premium speaker system (UQA). I am installing a Nav/CD/DVD Radio system (15940102), including Bose Amp (15913905) along with the center console, from a junked 07 Tahoe interior. I have access to junked vehicle's dash if there is anything I forgot. Installation went OK except none of the volume controls (on the radio and steering wheel) work. The system is stuck with volume wide open. DVD works, Nav needs map disk, GPS signal not working yet but have not worked alot on that. CD works and is also wide open volume. All cables appear plugged properly in both radio and amplifier. Junked vehicle for Nav radio had 4rd plug with 3 wires for rear cam this vehicle does not possess. Other 3 plugs going to radio seem wired exactly same except for wire 4 on plug number 1 (black plug). The junk vehicle had a voice recognition audio signal (UE1) on wire 4 that the current vehicle does not possess. I have stumped 3 dealerships in Western NC with this so far. I am told the Tech 2 cannot find/connect to the amplifier. There is a stored code from the radio, DTC B0000 (Vehicle Speed Information Circuit Plausibility Failure). Troubleshooting suggests to check the serial data signal from the EBCM at > 3 mph. If good replace radio. If bad replace the EBCM. Theories are: 1. Incompatible wiring2. Automatic volume control over-compensating for bad Vehicle Speed Information (Thinks vehicle is going extremely fast and turns up volume to cover sound of impending crash I assume)3. Bad Radio head unit4. Bad Bose Amp. While my 15 year old son can see no problem, I would appreciate any reasonable suggestions on how to make this configuration work. I do have access to GM tech willing to tinker using the Tech 2 as needed. Thanks in advance.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 279 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
