04 Trailblazer
75HOW30
Got a 04 Trailblazer that is quiet when cold, problems is when it gets up to operating temp it gets a "ticking" noise. Noise is mostly heard from underneath and sounds a lot like a loose torque convertor bolt (sounds like crankshaft speed and is relative to engine speed, also is there at idle in any gear selection). Can be heard near flywheel area. Checked all torque converter bolts and they are tight. Removed torque converter bolts and inspected - no signs of rubbing/hitting anything. Started engine with bolts out and noise is gone. Reinstalled bolts and noise is back. No obvious signs of a cracked flywheel, although I cant rule this out untill it is removed and inspected closely. Was wondering about torque converter or trans pump noise.
Thanks in advance.
26 views with no replies doesnt sound good. :cheers: Gonna pull the trans tonite and hope for a cracked flywheel or a bolt sticking out of the back of the block contacting the flywheel.
I didn't respond because it sounds like you are on the right track. We have tick noise issues with valvetrain and one particular noise with the fan clutch at idle that there is a reprogram for but you seem to have it nailed down to the other side of the engine.
Yeah I know about the 1 second interval tick at idle from the fan clutch and the reprogram. This vehicle does have that noise also, but at this time Im not worried about it. I pulled the trans last night and found nothing so far. :fume: Flywheel is in great shape, especially for 140,000 miles. The starter gear goes back in all the way and flywheel teeth look good. Did not have my trans tools with me, so looks like I will be going into it today. No bolts sticking out from enigne block or the trans (thinking possibly contacting flywheel or converter). My ideas are possible converter or pump, but not sure :cheers: . If you think of anything please let me know.
I don't do much trans work but I think I would replace the converter and pump while you are there just in case. I don't think you will see anything wrong with either one because the noise is going to require some load and pressure. Hopefully you get lucky and see something. I know that is a bit pricey to just throw at it but for my money it's more pricey time wise to be in there suspecting a problem and not doing anything about it. Good luck to you. While you are at it I would check crankshaft endplay, possibly taking the load off the crank made the noise go away if you have too much.
Pulled trans apart and found LOTS of metal particles in fluid; no peices or anything to tell me exactly where they might come from. Converter has metalic looking fluid, pump and cover are scored, valve body has several scored
valves, input housing has enough of this "overheated metalic fluid" "baked" onto it that I can actually scrape it off. Several bearings sound rough. :D Did not go any further---- It needs a new trans and we are currently looking for a good used model. Will let ya know after replacement, but Im sure that will fix her. :D
Thanks
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,251 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
